Question about Microwave Ovens
Ge profile advantium 120 SCB2000FCC 02
Control panel scrambled display, beeps and select is displayed but not responding, turned main breaker off but display still shows scrambled
SOURCE: control panel "locked" on ge advantium 120
You might have set the child lock. Look in the manual. It is on P.36 in my manual.
Posted on May 16, 2009
philbran
  • 242 Answers
SOURCE: Advantium 120 (Display Pad is not Illuminated or Working)
try removing the touch pad/switch membrane and cleaning connections on ribbon cables. if problem still exists replace switch membrane.
Phil
Posted on Jun 11, 2009
woobie dog
  • 1273 Answers
SOURCE: I have a GE profile advantium 120 . The panel
Check your power setting, making sure that you are cooking at 100%. Adjust if necessary.
It could also be a bad magnetron.
Regards, --W/D--
Posted on Jul 23, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Display on my ge Advantium 120
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try it again.
If it's still not working, it may have a failed keypad or a problem with the controller.
The full service / installation manual is here.
We repair these all the time, and would be happy to help you with more info at no charge. Feel free to contact us.
Posted on Aug 19, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: need to unlock the control panel on my GE
If that doesn't work, leave it unplugged for about 5 minutes.
Then I would refer you to the owner's manual.
If for some reason you don't have yours, y
ou can download GE owner's manuals and installation instructions here.
Posted on Sep 08, 2010
Just stopped working panel displays time etc but no microwaving going on
  • Open internal fuse
  • Defective magnetron
  • Defective control panel
Jan 29, 2017 | Microwave Ovens
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
Display is blank
If the display is blank, and the oven works, 9 times out of 10 it is a problem with the circuit board that drives the display.
Apr 16, 2014 | GE Advantium 120 Convection/Microwave Oven
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
GE Advantium 120 oven: Was boiling water and oven completely powered off. House circuit breaker is OK and not tripped. Plugged into another working outlet with extension cord to see if display came on. It...
You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
Feb 05, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Phil
Jun 11, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
Advantium
Can you take a digital photo of the display and upload it here so I can get a better idea of it? Do you use a spray cleaner directly on the keypad? Sometimes moisture can get into it and scramble the controller. I always advise my customers to spray a cleaner on a soft cloth, then wipe the keypad off.
May 21, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
