Question about Dishwashers
Frigidaire gallery professional series oven
We had this problem before, but then the burners on the left side would not turn on. They still turn on, but you can't set the temp for anything ending with a zero. We replaced the board in the back less than a year ago. . . . . . what else could it be? No wonder Frigidiare is no longer in the United States. People would be tracking them down and loading their junk appliances at their back door. Sorry. . .just a little perturbed. What could it be?
SOURCE: Frigidare Gallery Pro Dishwasher Control Panel Power
It can be the problem with the transformer. Try replacing it with another one.
Posted on Dec 15, 2008
  • 40 Answers
SOURCE: loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Posted on Feb 23, 2009
SOURCE: Oven door locked and fan going frigidaire professional range
Did you solve your problem? I just got stuck in the same situation! How did you stop it?
Posted on Aug 17, 2009
localwonder
  • 6784 Answers
SOURCE: I have a Frigidaire Gallery Series dishwasher,
HI. this noise will most likely be a damaged pump impeller. It may be loose, cracked,misaligned, or totally separated for the drive stud. The pump is accessible be removing the sump cover and extracting the pump housing. I recommend checking the impeller for damage. replace any failed components that may be visible during the inspection.
CLICK HERE TO ACCESS A COMPLETE PARTS LIST AND PUMP ASSEMBLY DIAGRAM.
Posted on Sep 14, 2009
SOURCE: frigidaire professional series electric oven door won't open
MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE PROFESSIONAL SERIES STOVE 31606390
Posted on Jan 03, 2010
Frigidaire gallery professional series oven I have
Good Afternoon John, I am happy to assist you!
I understand you are seeking a manual and I'm assuming your model number is GLEFM397DS, posted above. If so, I have located the Owner's Guide on the manufacturer website. Here you will be able to access step by step instructions on how to operate the oven. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Sep 16, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery Series Electric Oven has stopped working. I was trying to preheat the oven and after a few minutes heard a very loud pop/bang. The oven had the PF (power failure) symbol flashing and my...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 07, 2010 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery Professional Series Oven Won't Turn On
Suspect a bad oven element. Worse case is a bad oven relay on the clock control board.
Sep 20, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Hello! I have a Frigidaire (made by Electrolux) Gallery Professional Series gas range/electric oven, model #FGF379WJCA (manufactured in 1998). The appliance came with the house we moved into 2 years ago. ...
for question 1 the wire for the ignitor is bad has to be changed not an easy job if you can live with it itll be ok if not its best to call in a tech or take to repair shop not sure about question 2 sorry
Aug 30, 2009 | Electrolux Frigidaire Professional Series...
My smooth top burner will not work
The #1 most likely problem is that you don't have 240 volts to the unit. Your clock and lights will come on but not the burners or the oven elements. Turn off your breaker and then back on. If this doesn't correct the issue...#2 Check your cord and the terminal where it attaches to the stove for a burnt connection, WITH THE POWER OFF!!! #3 Call a technician.
Dec 09, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Gallery Stainless steel convection oven professional series
i have a frigidare gellery oven i cleaned it and now my broiler an oven wont work
Jul 04, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery series stove top stopped working.
This sounds like a burner control. You may be able to do the job yourself. If you order the part, it should plug in. Remember to turn off the power. Any online source should have the control.
Jan 10, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Dec 16, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dishwashers Logo
Top Dishwashers Experts
