Question about Maytag MER5770 Electric Kitchen Range
Back burner not working on Maytag ceramic top stove
Back burner on my maytag ceramic top stove stopped working after seeing a spark. How do we replace the element?
5 Suggested Answers
  • 530 Answers
SOURCE: Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
Posted on Jan 04, 2009
  • 105 Answers
SOURCE: Maytag Electric Ceramic Glass top stove
You can replace the failed component which is either the burner or the switch that controls the burner. A voltage test would have to be done to determine which compoonent has failed. Generaally it is worthwhile to repair the range.
Posted on Apr 08, 2009
milten1
  • 1304 Answers
SOURCE: Hoow do I remove the top froma maytag range?
there should be two small screws on the corners thay are black so you really gotta look
once removed your top should flip up
Posted on Oct 03, 2009
EllaWatson25
  • 725 Answers
SOURCE: where can I go and get directions on how to
Good afternoon. We are Maytag factory authorized service and parts suppliers and have all the solutions for your Maytag appliance issues.
We have the proper element for this model and can get it out to you asap.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST and we will get your parts out right away.
We look forward to hearing from you. Thanks, Ella
Posted on Jan 18, 2010
Maytag stove
Take an emory board or trim a piece of sandpaper so it is about 1/2" wide strip. Take the burner grate and plate (if applicable) off. There is a cover over the ceramic cylindrical spark unit. The spark is there but there is no connectivity to cause the arc to light the gas. This is due to grime and oils that accumulate over time on the bottom of this cover. Take your emory board or sandpaper and buff up the area that sits right on top of the spark unit. The roughing up actually cleans the area so your sparker can light the burners. Good luck.
Apr 29, 2014 | Kitchen Ranges
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Aug 06, 2013 | Cooktops
I have a maytag performa ceramic top stove andwhen I turn on the oven it will only heat up to 230 degrees
I have a Maytag Performa Ceramic stove top which I have "washed" the serial number, I broke the glass top and need to replace it, but I don't have the model/serial number. If anyone has one please give me the numbers. Thank you
lilkadoc@hotmail.com
Apr 27, 2010 | Maytag Kitchen Ranges
CERAMIC COOK STOVE TOP CRACKED
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
Feb 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Can't start oven. Stove top works fine. Maytag
top burner burnt out we replaced it with a new one and it still doesnt work please help? Ron
Jul 09, 2009 | Kitchen Ranges
Apr 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Jan 04, 2009 | Maytag MGR6775 Stainless Steel Kitchen...
(2) front Burner igniters on my new Matag 30" Cooktop continue to click
Sounds like water got into one of the switches. This usually happens when you wash the knobs. Water stays in the holes and runs down the shaft when replaced. Maytag has issued a recall on some stoves because this can be a fire hazard. UNPLUG THE COOKTOP UNTIL THIS IS FIXED!!!!!!!!! This has happened to me with a whirlpool unit and it tripped a breaker and shot sparks across the kitchen. First go to Maytags web site and see if yours has a recall. If so Maytag will fix it free. While you are waiting leave stove unplugged and light with a match. If you need to fix this yourself disconnect the wires from the two switches this should stop the sparking. Connect one switch at a time and see which switch is bad. Most of the time the electric part of the gas valve can be replaced seperately. and you can do this yourself. If you must actually disconnect a gas pipe unless you really know what you are doing call for service.
May 15, 2008 | Maytag 30" Built-In Gas Cooktop - White
Schott Ceran cooktop on Maytag range
try clr from a local supermarket.it comes in a green plastic bottle.wipe the burner generously but not soaking wet with it and turn the burner on the lowest setting.then use a metal scouring pad and LIGHTLY scour the burner.
Aug 11, 2007 | Maytag MER5775Q Electric Kitchen Range
Maytag MER5770 Electric Kitchen Range Logo
19 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
