Question about Wmf/Usa 4.5qt Stainless Steel Perfect Plus Pressure Cooker
Perfect pressure cooker f3 - Wmf/Usa 4.5qt Stainless Steel Perfect Plus Pressure Cooker
How do I get the helper handle to stay on
Here is a review of the WMF pressure cooker, in the performace section (bout the middle of the review) are detailed step-by-step photos on how to get the handle on and off.
http://www.hippressurecooking.com/pressure-cooker-review-wmf-perfect-plus-rating/
Make sure that the red lever is pulled back when the handle is on and that it snaps back into place on the underside of the lid.
May 31, 2014 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
We took the pot away from the heat and let it cool. After checking that it was assembled properly, put it back on a much lower heat setting and it is fine now. It appears that the heat on this pot has
Here is a detailed description of how the pressure cooker should work. The "fog horn" should not activate until the second red ring is out of the housing.
Dec 07, 2012 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
The pressure does not build up and the valve does not rise
There are photos of the WMF handle here. Make sue it is installed correctly, and the handle is in the locking position
Apr 02, 2012 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
I have a 3L 22cm wmf perfect cooker which leaks, can you help?
Make sure the gasket is in the right position, the handle is placed on correctly and the slide on the handle is in the locking position. Here are more details on how to use this pressure cooker.
Aug 24, 2011 | Wmf/Usa 2.5qt Stainless Steel Perfect Plus...
Can I get a copy of Chinese user manual for Perfect Pressure Cooker?
Here are all of the pressure cooker manuals for WMF pressure cookers:
http://www.hippressurecooking.com/category/manuals/wmf/
Aug 18, 2011 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
No.1 part, the round whistle in the middle of the lid doesn't pop up when the cooker is on and pressure is building up instead the steam comes out of small pressure ball and it sprays everywhere.
Here are detailed instructions on how to use it. It sounds like the slide on the handle was not set to the locking position:
Mar 22, 2011 | Wmf/Usa 2.5qt Stainless Steel Perfect Plus...
E4 code on model epc460 pressure cooker
I have a programmable pressure cooker with no instruction manual. The model number is EPC460. It was made in China and just says Perfect Programmable Pressure Cooker. Can you help me find a user manual for this. I can't find anything online or by googling it.
Thank you
Jan 21, 2009 | Cook's Essentials Cooks Essentials Arome...
Wmf/Usa 4.5qt Stainless Steel Perfect Plus Pressure Cooker Logo
Top WMF Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a WMF Kitchen Appliances - Other Expert? Answer questions, earn points and help others
