Question about Winegard Carryout Satellite Dish - Wineguard
Winegard carryout wont work
It has 12 volts of power but still wont move the lnb at all
Fan wont come on
Make sure that the fan is 12 DC Volts.. If that is 12 DC volts?... you can connect that fan to power supply of your desktop wired color (+)yellow and ( -)black. If its doesnt work... that fan is defective.
Aug 16, 2014 | Computers & Internet
Too much power and now lorex camera wont turn on
CAMMERA DESTROYED !! MOTION LIGHTS USE 120 VOLT AC POWER
CAMERAS USE 12 VOLT DC POWER
WRONG TYPE AND AMOUNT OF POWER !!!
Jan 16, 2014 | Lorex Home Security
Wont start,no sounds no power,completely dead
You will need a volt meter to figure this one out. Battery voltage? Should be above 12 volts, and while you are trying to "crank" the engine over, if it's still over 12, you need to see if that power is getting to the starter motor. If it goes below 9 or 10 volts, you either have a bad battery, or the starter motor is shorted, or bad.
To test the starter, you should have a large wire going to the starter that has 12 volts all of the time from the battery. A smaller wire will have 12 volts only when the key is turned to "start". If you have these and a good ground, the starter motor is bad.
May 30, 2010 | 1997 Toyota Corolla
Even Transponderds Zero
Typically that indicates a bad LNB or connection to the LNB. Try moving the line to one of the other three ports on the LNB and if that doesn't work then you will need to replace it
May 18, 2017 | Directv HR10-250 DTV Receiver
LNB went bad replaced and unit worked for the people for four days and LNB appeared to of went bad again. This time i measured the voltage to it and it was 33 volts instead of the recommended 13-18volts.
if you take the cover off the receiver and look at the power board you will find evidence of overheating and probably some capacitors that are bulging. it's probably cheaper to buy a new receiver unless you are able to start replacing parts yourself. I found a overheated board recently that came from factory with R30 missing.
Sep 15, 2009 | Fortec Star Lifetime ULTRA
Lost all Satellites
I don't remember exactly but vert is 13 volts and hor is 18 volts or vice versa..its one of these ways
Aug 05, 2009 | Arris DSR922
I have a viewsat ultra. It will turn on.. but if I have the cable from sat in the back of the receiver,.. where it should be in sat in.. it wont turn on... but without my cable from the dish itself it will...
If you are using a switch between the viewsat and the LNB, remove it and connect the receiver again.
If that did not work, remove the cable from the LNB and power up again; if the receiver still unable to power up then you might have a short circuit in the cable itself or water might be entrapped inside the connectors on the LNB/switch connections.
Let me know if you need further assistance.
Jan 08, 2009 | Yamaha HTR-5730 Receiver
Directv h20 receiver has low volyage to the lnb.
Check inside the receiver for a defective LM317 IC or a TIP42C transistor, but before that you should check for proper voltage from the power supply to that IC.
LM317/TIP42C control the switching of voltages that power up the LNB, you should be getting 14 volts for vertical channels and 18 volts for horizontal.
Good Luck.
Mar 08, 2008 | Philips DIRECTV H20 DTV Receiver
Winegard Carryout Satellite Dish - Wineguard Logo
66 people viewed this question
Top Winegard Televison & Video Experts
Electro Med Services...
Are you a Winegard Televison and Video Expert? Answer questions, earn points and help others
