Question about Pride Health & Beauty
Replacing oil in transaxle - Pride Health & Beauty
LEAKING OIL right transaxle
Johnny, Transaxle needs a new seal. you can get or order your seal from any local small engine repair shop. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
TORO Wheel Horse Hub Removal and Transaxle Seal Replacement
Replacing oil seal on rear axle of Lawn Tractor 917 288250 ShopYourWay
2007 Craftsman 917 287210 Lawn Tractor with leaking Transaxle
Rebuilding lawn tractor transaxle Part 1 of 2
lawntractor transaxle seal Google Search Ord
Aug 25, 2016 | Garden
Won't move forward or backward.
Most are sealed. Is your drive belt ok?
Feb 15, 2016 | Husqvarna Garden
Husqvarna gear oil
I assume you are referring the the transaxle? The replacement oil in the transaxle is as follows: This model ran either a Hydro-Gear or Tuff-Torque transaxle. If Hydro-Gear use: 20W50 synthetic. If Tuff-Torque use: 10W30 synthetic.
Apr 02, 2014 | Husqvarna Lawn Tractor Gth26k54t Owners...
1996 Honda Accord EX Manual trans. Where is oil level plug. what kind of oil?
All Honda manual transaxles use the Honda Manual Transmission Fluid (MTF) as the original factory fill. This oil is similar to a 10W-30 or 10W-40 viscosity engine oil, and this oil can be substituted temporarily. However, the manufacturer recommends the use of their MTF when changing the fluid.
Level Check
The transaxle fluid should be changed every 90,000 miles (144,000 km) or 6 years under normal driving conditions. In severe driving conditions the fluid should be changed every 30,000 miles (48,000 km) or every 2 years, whichever occurs first.
Make sure the vehicle is on a level surface. If the vehicle is raised, make sure the vehicle is safely supported and level
NOTE: Do not confuse the drain plug with the fill plug.
The fill plug is in the mid section of the transaxle. The drain plug is near the bottom of the transaxle.
  1. The oil level is checked by removing the oil fill plug on the side of the transaxle. The transaxle fluid should just meet the lower threads of the transaxle fill hole.
  2. Remove the oil level check bolt from the side of the transaxle. If oil runs out, or if oil can be felt near the threaded fill hole opening, reinstall and retighten the bolt to 33 ft. lbs. (45 Nm).
  3. If the level needs to be topped off, pour oil in slowly until it begins to run out then, install and tighten the filler bolt to 33 ft. lbs. (45 Nm).
Cheers,
"Please rate this solution or kindly leave a Testimonial"
Sep 05, 2011 | 1996 Honda Accord
How to change Radiator in 1999 Chevrolet Monte Carlo Radiator
Hello, here are the instructions for rad replacement
  • Remove air cleaner assembly and the throttle body air inlet duct. .
  • Drain the coolant.
  • Remove the engine strut brace bolts from the upper tie bar and rotate the struts and braces rearward. Refer to one of the following:
  • • Engine Mount Strut Bracket Replacement in Engine Mechanical - 3.1L • Engine Mount Strut Bracket Replacement in Engine Mechanical - 3.8L
  • Remove the electric cooling fans.
  • Remove the radiator bracket bolts and the radiator brackets.
  • Use the J 38185 in order to reposition the hose clamp at the radiator inlet hose.
  • Disconnect the radiator inlet hose from the radiator.
  • Use the J 38185 in order to reposition the hose clamp at the radiator outlet hose.
  • Disconnect the radiator out let hose from the radiator.
  • Remove the coolant level module.
  • Disconnect the transaxle oil cooler pipes from the radiator. Refer to one of the following:
  • • Automatic Transmission Oil Cooler Pipes Replacement in Automatic Transaxle - 4T60-E • Automatic Transmission Oil Cooler Pipes Replacement in Automatic Transaxle - 4T65-E.
  • Remove the transaxle oil cooler pipes from the retainer at the bottom of the radiator.
  • Remove the radiator.
    Jun 12, 2010 | 1999 Chevrolet Monte Carlo
    Replaced CV Axles, now Transmission Reverse doesn't work
    Bring it back to them and let them check the engine and transaxle oil levels. Let them do a OBD1 code test. Check the droping resistor to the transmission transaxle, Check the oil quality for the right oil for engine and transaxle , did they mix it up, Take camera and videocorder to record that .
    Vitally
    Sep 15, 2009 | 1993 Nissan Quest
    Hydrostatic drive squeels and stops pulling when hot
    I had a similar thing go wrong. Even though the hydrostatic drives are designed so that the fluid doesn't need to be changed, If it is a hydrostatic transaxle check to see if it is leaking,if it is then there really is no repair to transaxle. If it isn't leaking then It sounds like the oil in transaxle is worn.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 Allen wrench fitting on top. You will need to purchase suction bulb and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion
    Aug 13, 2009 | Mtd Garden
    Tractor moves but buck and learches
    If it is a hydrostatic transaxle check to see if it is leaking,if it is then there really is no economical repair to transaxle. If it isn't leaking then It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 Allen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
    Aug 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Where do you fill the transaxle with oil?
    Yes, engine oil is fine, and the fill plug should be like the drain plug but higher.
    Jul 30, 2009 | 1987 Chevrolet Spectrum
    I have a 20 hp craftsman lawn( hydro gear transaxle ) tractor in terrific shape that losses drive on a grade. I replaced the worn drive belt and it was good for the first few mows, Now Im right back to...
    It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
    Jul 15, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
    Health & Beauty Logo
    12 people viewed this question
    Top Pride Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Colin Taylor
    Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
