Question about Morphy Richards Jet Stream 42271 Iron
Brown water comes out of the iron when ironing
Brown water is worse at lower temperatures
4 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: we got 42303 iron and use filtered water but we
I would suggest using distilled water, since something in the filtered water is producing the scale. If you switch to distilled, that should eliminate the scale.
Good luck, and hope this helps.
Posted on Nov 15, 2010
Testimonial: "thanks"
SOURCE: Morphy richards jet steam iron.
my morphy richards steam genarator iron 42242 says it is hot enough but in fact sole plate is not and leaking water over garments.any ideas?email me t.hayward33@ntlworld.com
Posted on Apr 25, 2011
  • 383 Answers
SOURCE: the alarm on the iron comes on and switches off
What sort of Alarm do you get?
Does this iron have the 3-way alarm feature:
1.) Tilt over
2.) Laying down alarm (like 60 seconds)
3.) Idle alarm (like 15 minutes or longer..)
Can you give us more details on the alarm you get getting, and when?
Mack B
Posted on Aug 08, 2011
We have a GC8420 steam iron. The steam is regularly discoloured, first a pink, chalky stain - very difficult to get out of fabrics - and today a lot of dark brown/black water coming out. We do empty out...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Jul 14, 2011 | Philips Irons
How do I clean the water reservoir in my T-FAL Avantis 90 iron. When I use the iron hard particles come out of the steam holes.
heatman101
Mar 23, 2011 | Tefal Avantis 90 Iron
Rust colored steam that stains clothing ironed
heatman101
Mar 22, 2011 | Rowenta DZ1700 Iron
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
heatman101
Mar 16, 2011 | Rowenta DG-980 Iron
Brown water spitting out of bosch steam iron
Brown water and white scale are often the result of the water you use in the iron...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Feb 03, 2011 | Bosch TDA8340 Iron
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
Brown dirt coming out of steam iron
You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
Jul 01, 2009 | Sunbeam 4214 Iron
Shark Iron
The brown residue is probably caused by iron in the water. I would suggest you put a solution of half vinegar and half water into the water chamber and leave in the iron overnight.
Then switch it on to steam and holding the iron over the sink or over an old towel, the dirt (residue) comes out of the holes on the soleplate. Sometimes if the iron is badly scaled you might need to repeat the descaling.
Once complete fill with water and steam away, to flush any of the remaining vinegar out of the iron.
Depending on how often you use your iron and how much iron is in your water, you might consider performing this flush process every 2 or 3 months. It will help extend the life of your iron.
Good Luck
Aug 11, 2008 | Euro-Pro Shark GI490 Iron
Brown spots coming from steam iron
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Jun 23, 2008 | Oreck Cordless Speed JP8100CA Iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Nov 15, 2007 | Irons
Morphy Richards Jet Stream 42271 Iron Logo
47 people viewed this question
Top Morphy Richards Irons Experts
Mack Baxter
Are you a Morphy Richards Iron Expert? Answer questions, earn points and help others
