Question about Garden
Hayter problems I have a heritage 13/30 and it won't start at all - any clues please.
Blade not turning hayter heritage 13/30 ride on
Your seat switch may be bad.
Oct 14, 2017 | Garden
No spark at plug
Remove small kill wire to coil see if it will start if so you will need to find where this wire is grounding out.
Sep 09, 2017 | Garden
How is the rear wheel of a Hayter Heritage removed?
most of them have a split ring or snap ring that needs removed then the wheel just slides off . manu rust in place and need persuasion to get off .BRUTE FORCE
Jul 30, 2016 | Garden
Hayter jubilee 43
Sounds like the fuel system need to be cleaned out. I woudkl also check for grass clogs and a sharp blade.
Sep 07, 2014 | Garden
Briggs instructions
Locate the drain plug on the bottom or side of the engine (might have a drain pipe attached to it) remove plug let oil completely drain screw off filter and replace (if equipped) refer to manual or Google and find out how much oil the engine holds (maybe around a quart) replace oil check for leaks and go mow your grass
Aug 15, 2014 | Briggs & Stratton Garden
2001 heritage softail that won't start, please HELP!!!!!
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
May 11, 2013 | 2000 Harley Davidson FLSTC Heritage...
TRANSMISSION LOOSES PULLING POWER AFTER WARNING UP
the first step is to replace the air filter you'd be suprisied.then the fuel filter .take a test run after that.hope this helps
May 10, 2009 | Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
