Question about Kitchen Appliances - Others
Burner has yellow flame
Flame is supposed to be blue with little to no yellow but it has a lot of yellow
bigg t
  • 640 Answers
SOURCE: adjusting main burner flame
Goto the gas valve,you will see 2 slotted silver caps 1 small 1 big.unscrew the big cap then youll see a white plastic screw.turn this screw counterclockwise to increase the gas pressure,clockwise decreases pressure.nat. gas pressure should be 3.5 inches of water colum
Posted on Feb 12, 2008
bigg t
  • 640 Answers
SOURCE: Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Posted on Sep 04, 2008
  • 125 Answers
SOURCE: one burner puts out soot.
Hi there, I believe that the burner you are having a problem with, needs the inside of it cleaned, probably has alot of dust inside, or some material is in/on the orifice where the gas enters, you could also have an alignment problem with the orifice, causing a disturbance in the flow of the gas/air mixture. In addition it sounds like you may have a gas pressure problem, you should contact your gas supplier to have it checked, or call your local service company.
Hope that helps, and thank you.
Posted on Feb 21, 2009
  • 199 Answers
SOURCE: yellow flame on the rear of my burner
Yellow is a "reducing" flame meaning low oxygen, whereas blue is an oxidizing flame. There is not enough air mixing with the gas. Clean out the pipes and free the air intake holes on the first stage of the burner assembly.
Posted on Jun 20, 2009
bulldogchief
  • 388 Answers
SOURCE: tried to use my turkey fryer and could only get a yellow flame
Check your propane tank first; is it getting close to being empty? Check where the hose connects to the burner, there should be an air adjustment there; it looks like a rotating disc with two big holes on either side, this is turned when the burner is lit to adjust the amount of air mixing with the gas. If it's all the way open, you have a yellow flame, if it's closed all the way you have a blue (but weak) flame. Try adjusting that and if that doesn't work, try a different regulator...it is rare a regulator could cause this but it could cause it; just use that as your last resort.
Posted on Dec 04, 2009
Testimonial: "Thanks for the heads up! I'll check it out as you discribed. Merry CHRISTmas!!! Steve"
How do I adjust the side burner on my kenmore gas grill?
You should find an air mix adjustment for that burner. Try opening it a little, to allow more air. A yellow flame indicates too rich a mix.
The adjustment is probably behind the knob for that burner.
Aug 10, 2014 | Kenmore 4 Burner Gas Grill with Side...
My flame has a lot of yellow in it instead of pure blue
The air intake on each burner needs adjusting, as you have an improper ratio of gas to air. The burner flames should have blue base with yellow tips.
Jan 25, 2011 | Char-Broil 6975194 Big Easy Srg Cover
FLAME IS YELLOW INSTEAD BLUE for sunbeam gas range
Yellow usually means more air than gas mixing at the burner. The top of the stove lifts off. There are adjustment screws in front of every burner. Turn the burner on after first locating the screw. Turn the adjustment screw until desired flame is achieved. You want a flame with a yellow tip and the body of the flame blue. Please be very careful not to get burned. Hope this helps.
Jan 20, 2011 | Sunbeam SNS3GMNBB (Gas) Kitchen Range
ON MY ATWOOD WATERHEATER IT LIGHTS BUT PRODUCES A LOT OF SOOT AND DOES NOT SEEM TO FIRE UP LIKE IT SHOULD
You need to start by cleaning burner tube and pilot intake , sounds like spiders have probably spun a web in there. If flame is yellowish, it's not getting enough air. You can buy a barbecue burner brush, long and flexible, and run it through burner tube to clean out web, and if pilot is yellow as well, there is a small hole in side of fitting where it attaches up near burner that needs to be cleaned out with paper clip or even better, compressed air. After cleaning burner, adjust air shutter to get nice blue flame, with just a hint of yellow at tip. The idea there is to get blue flame, but not a roaring flame that is jumping off the burner. A spider web in there will usually allow propane through, but restricts air mixture, thus causing yellow flame (rich mixture) and soot to build up.
Nov 11, 2010 | RTO Atwood Water Heater - 6 Gal LP
When one of the gas hobs is on ,it does not burn with a blue flame but a more yellow one .also black soot forms under the burner plate.it is on lpg
Have to adjust the piolot lights for the amount of gas coming out. U have too much gas coming out(yellow flame). On older gas ranges, there was a small screw between the piolot light & burners that had to be adjusted. (if this is a older model) have to turn the screw just a little at a time, till ur flame returns to blue on ur burners. Hope this helps.
Sep 12, 2010 | Microwave Ovens
Dynasty gas range - orange flames
It is normal, it will disappear after a little while, when you bang on the burners, particle fell off form inside of the burners and it caused the orange flame. Yellow flame means not enough air or burner is internal clogged.
Feb 15, 2010 | Dynasty DGRSC 36-6 Gas Kitchen Range
How do I know if the appliance store actually changed my cooktop to LP with a conversion kit? I'm beginning to wonder because I found a conversion kit in a box of supplies...it's been a year since they...
You should have voiced your concerns long ago with the store you purchased it from. But if they did not convert it, you would have large, yellow flames.Proper burner flames will have no yellow in them. They should be only a blue flame.
Jan 10, 2010 | Thermador PGR366 Gas Kitchen Range
Lots of yellow - then very low heat
Are the flames still yellow? If so the burner just needs to be adjusted which is very easy? Look at the ends of the tubes that come out of the burner and end right at the back of the gas controls. You should see a small piece of metal that will slide or spin to close a hole. You want to close or open it a little at a time while the grill is burning. Adjust this until you only see blue flame or blue flames with a little bit of a yellow tip.
Jun 13, 2009 | Char-Broil Commercial Stainless Steel...
Yellow flame on the rear of my burner
Jun 02, 2009 | Char-Broil CharBroil Master Flame Gas...
Kitchen Appliances - Others Logo
24 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
