Question about Royal 9500ML Cash Register
Journal paper won't advance - Royal 9500ML Cash Register
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
After reset my journal not printing automatically..what i need to do for it?
Go to system options and set E/J to off then you hard journal will be on
Mar 18, 2015 | Retail Supplies
Justice password journal low batteries
I used a set of cutting pliers and lifted the back two rivets off. Then i gently peeled the paper up and slid a knife under the strap that was glued down. Replaced the batteries, put the rivets back in and used a small screw driver to mesh the strap back on the rivets. Lightly re-glued the strap and scotch taped the paper back on. Back in business, made one girl happy!
Dec 26, 2013 | Justice Girls Electronic Password Journal
My casio PCR -T2000 won't print receipt paper. The paper is not moving. There is no error on the screen. There is no jam. It is the correct thermal paper. I've tried turning power off and on and...
You haven't mentioned the journal roll, so I will assume it prints the journal but not the receipt. What happens if you press the post receipt button at the end of a sale. Does it print daily reports on both rolls? --------------------------------------------------------------------
If anyone needs a Casio PCR-T2000 manual, C-tech collective have it here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Jul 25, 2011 | Casio Parts Cash Register PC Desktop
Fax Journal
To print out a journal:
Press function 61 set
press 2 for print.
The machine usually only keeps the last 50 transactions in the journal.
Jan 23, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Verification stamp
there is no function to print it on the fax you sent but you can have a come journal.
press the following.
function-7-4-start-1-2-start-2"should say always" start stop then this will give you what you want
Jan 20, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
Paper
Hi. The PCR-T470 is only a single roll machine, so if you had them printing at the same time, you would be handing the customer your journal when you gave them their receipt. This machine can be setup either as journal only (in which case you use the black takeup reel that sits inside the printer housing), or receipt mode (in which case you have the paper coming out of the front of the printer cover). The best thing about single roll machines is that when you have them in recipt mode (recommended), you can print the journal out of memory whenever you want. to do this, turn the key to X mode and press RC button until you see 'electronic journal', then press CASH to print it. you might be able to reset the journal by doing the procedure in Z mode (the manual isn't clear about this). Give it a try.
Hope this helps. Let me know if you have more trouble.
Mark
Sep 04, 2008 | Casio Parts Cash Register PC Desktop
Royal 9500ML Cash Register Logo
Top Royal Retail Supplies Experts
Patrick Tinashe...
Electroboy
Electroboy
Kevin.
Are you a Royal Retail Supply Expert? Answer questions, earn points and help others
