Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Maytag washer I have a Maytag front loading washer, model #MAH2400AWW, it will do all the cycle except spin. If you put it on spin only it will start to spin then after about 2 or 3 revolutions it will stop and after several minutes it will show a 3E code on the dispaly read out. Any suggestions?Thank you Kennetha Noble
  • Anonymous Jan 28, 2009
    Washer does everything but spin.
    Checked spin in service mode; won't spin
    Checked motor in board output test; rotates one direction only
    Checked ohms test; 2.5 0k
    No leaks inside
    Drain pump works
    No fault code
    signed, Springbok
3E has something to do with the motor control. Apparently the design of this machine allows a water leak either from the water intake box or down a rubber hose which runs along with the motor wire harness. The water tracks to the harness and motor and shorts the whole mess out. a.k.a. fried motor.
pull the back plate off (3 screws) and look at the motor where the wire harness plugs into it. Notice a bunch of green stuff- that is corrosion from the electrical short circuit causing your problem. See the rust build up on the side rail below the motor (as there will be none on the side adjacent) this is indicative of a water leak.
Our machine started doing this within the first week and we had the "service" people come out and "fix" it, but it appeared they did nothing. When I opened the machine up I discovered the problem when I ohmed out the rotor contacts in the motor wire harness and found it to be open instead of the factory specs of appx 2.5 ohms.
Maytag (now Whirlpool) does not want to send me a new motor and harness because of their bad design. The machine is a sealed unit only 23 months old. Note to all...do not buy Maytag or Whirlpool. That Maytag repair man is sitting on his bum because the company does not care about their consumers and their cheaply made products (sold at high markups).
If you want pictures write me at aboxoffrogs@gmail.com
also in my model I found the troubleshooting guide in the bottom front kick plate. It is a plastic piece you will have to insert a screwdriver into and "pop" off. This will show you how to enter the "secret" trouble shooting codes into the front control panel. And a definition of exactly what 3E means.
Posted on Dec 24, 2007
    Scholar:
  • 146 Answers
Does the water drain out? If water is not draining out, the machine will not spin.
Posted on Nov 05, 2007
Maytag washer leaking from bottom
This is a fix for the Maytag MAH2400AWW, the machine kept displaying SUDS, the machine is 2-3 years old and it started doing this 4-5 months ago. I cleaned out the washer, and used HE detergent, ran it empty, to try to flush it out, used approved cleaners and ran it throught the cycle, still no good. I finally took out out a maintenance contract with BSF, the service guy came out today pulled the pump off and showed me inside it was missing half of the blades off the impeller. I remembered a year ago a coin had wedged in the pump which I took out and put back, not realising it had taken some teeth off the pump. Therefore the pump was not able to pump out the sudsy water very well which was staying inside the drum causing the suds light to come on, they installed a new pump for me, which was covered in the contract for free. Now it's working like new again.
Mar 06, 2012 | Maytag MAH2400A Front Load Washer
There is a grinding noise during the wash and spin cycles.
hello,
the problem is from the jet strew it indicate that the jet strew need to be reset it at the back of the washer it is connected to the main drum it is commonly call propeller or roller it is the cost of the noise
because it has loss it position connected to the drum
unscrew the washer and see the propeller connected to the drum .
thank you and thanks for using fixya.
Jun 11, 2010 | Maytag MAH2400A Front Load Washer
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Maytag mah2400aww 3E error and it will not spin
I have this problem with my unit. Called Maytag and got blown off. Unplugged the unit for 24 hours and it reset. Ran fine for a while but the problem comes back.
Jan 14, 2010 | Maytag MAH2400A Front Load Washer
The Maytag repairman says my model number is MAH2400AWW. You tell me: No manuals found for mah2400aww manuals. What now?
Check for yourself, pull the washer out, and check the back. model numbers/serial numbers are normally tagged on the back.
Dec 31, 2009 | Maytag MAH2400A Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAH2400AWW washer won't drain
pump is plugged unplug washer lean back against wall under unit right front 2, 5/16 screws lets pump free take hoses on both sides free check for coins after pump and objects before pump and in pump clear reinstall if clear replace pump just had 2
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Mah2400aww
The problem is the washer is defective.
Jan 18, 2018 | Maytag MAH6500 Neptune Front Loading...
Maytag front loading washing machine
3E = Drive system is not working correctly. Bad windings, speed sensor, wiring connections or Control Board.
Jun 12, 2008 | Maytag MAH2400A Front Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
503 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
