Question about Dryers
Error code C5 Whirlpool Cabrio dryer
Dryer will not start.
SOURCE: error code AF Whirlpool cabrio dryer
I found the answer to the code AF also and it means the air flow is blocked. I checked my dryer vent on the outside and it was clear. However when I removed the dryer duct it was clogged just inside the machine. I had washed and dried a blanket that shed alot!
Posted on Jan 10, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Cabrio Dryer 3 months old
"AF" is a restricted air flow condition. You say you've only had your dryer for 3 months, but have you ever cleaned the ducting? You need to check the lint screen after every load, AND you need to perform routine cleaning of the dryer venting (inside the dryer, as well as the vent line from the dryer to where it exits the house) about every three months. If left in this condition, the dryer heating circuitry will eventually failed and/or you could cause a fire hazard. An easy way to check to see if you have a clog somewhere is to remove the dryer vent hose from the back of the dryer. Run the dryer to see if you have air flow coming from the back of the unit. The air should be about 140 degrees F and forceful. Check to see if the error comes back. If everything runs fine, then you know the problem exists in the vent line between the dryer and where it exits the house. If you still have problems, you will need to unplug the dryer, remove the back panel and inspect the interior for clogs. At least you have a dryer that warns you when the air flow become restricted or blocked. Most dryers will continue to run until they overheat or fail. I hope this information is helpful. Post back with your comments and let me know.
Posted on Jan 27, 2008
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
SOURCE: Whirlpool Cabrio dryer won't start - the "sensing" light is on
where are the answers on those stupid site
Posted on Oct 21, 2009
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Posted on Jan 19, 2010
What does code f24 mean on whirlpool cabrio dryer
Inlet Thermistor Open F-24 flashes if the inlet thermistor is open. This fault code will ONLY appear when in the diagnostic test mode. See TEST #4a.
http://dryernotheating.net/whirlpool-cabrio-dryer-error-codes/#F-24
Feb 14, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I am getting an error code of AF when my Whirlpool Cabrio wed7300xw0 dryer is in operation. How can I fix this problem?
This is fairly common most of the time the blower drive belt or pulley has fallen off. This video should get you headed in the right direction. Although the video below shows a maytag dryer it is the same cabrio style dryer you have.
Sep 08, 2015 | Whirlpool Dryers
My dryer will not run. Code C5
Clean lint screen. Then exhaust hose maybe clogged or pinched.
The drum is getting hot could be just took many items in dryer
Jul 17, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
What does F1 mean on a whirlpool cabrio dryer
You can google whirlpool cabrio dryer codes and find the code that you are looking for. I just looked it means your dryer is not heating.
http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/
Aug 02, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
F1 code on my Cabrio dryer
According to the manufacturer the "F1" error code means a primary control failure. The correction is to replace themachine control assembly. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio dryer won't start - the sensing light stays on
An EXTREMELY helpful technical guide is folded inside the console housing.
WARNING: It is for appliance techs, DO NOT do the voltage/resistance checks if you are not well-versed in troubleshooting appliances! BUT, it does include putting the dryer in diagnostics mode and checking the sensors.
Post back any error codes you may get.
Oct 22, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a whirlpool cabrio dryer and it is showing AF on the display and it isn't drying. what could be the problem?
AF Error Code for the Whirlpool Cabrio Dryer is a Air Flow problem. Check your dryer vent and the outside exhast vent.
Jan 13, 2010 | Dryers
Dryers Logo
456 people viewed this question
Top Dryers Experts
