How do i reset my Surfeasy key to factory settings
How to reset clock on 6520 mpbile
Follow the instructions on the screen to set up your phone and prepare it for use.
  1. Find "Reset all" Press the Navigation key. Select Settings. Select Security. ...
  2. Restore factory default settings. Key in the phone lock code (default is 1234) and press the Navigation key. Press the Navigation key to confirm.
Doro 6520 - Restore factory default settings - Device Guides
https://userguide.vodafone.co.nz/doro/6520...os/basic.../restore-factory-default-settings/.
or go to this link might help.
How to reset clock on 6520 mobile Google Search
Oct 28, 2017 | Computers & Internet
Tip
How to hard reset or factory reset T-Mobile G1 phone
Hard reset or Factory reset will restore the phone back to its factory settings; the way it was when it was first bought or the way it was when it left the factory.
Note that this will erased the entire phone's memory (NOT memory card) and settings to the way it was when it was first bought.
How to hard reset or factory reset T-Mobile G1 phone:
  1. Switch off your G1. *If it won't your phone won't switch off, take out the battery and reinsert it after a few seconds.
  2. Now press the 'Power' key and 'Home' key at the same time and hold it for 20-25 seconds.
  3. Then you will see on your screen a yellow triangle with an exclamation mark in the middle.
  4. After that, press 'Alt+L' key on the QWERTY keyboard (to clean the phone completely).
  5. Next, press 'Alt+W' key (to factory reset it)
  6. Again, press and hold 'Power' key and 'Back' key at the same time for 20-25 seconds.
  7. The reset is complete.
on Feb 25, 2010 | T-Mobile G1 Android HTC Google Smartphone...
How do you hard boot into recovery mode,volume down and power then release both and press again on lg screan dont do it both ways only factory reset
Do not forget to backup your phone’s data before doing a factory data reset. Here’s our guide.
Performing a Factory data reset restores your device to the original factory settings as it comes out of the box. It also deletes the data like installed apps, contacts, messages, images, etc. present on the internal storage. It does not, however, affect any data stored on the external SD card. Now here is how you can hard reset your LG G2/G3 from device Settings:
Tap the Menu key from Homescreen.
Select System settings> General.
Now scroll to PERSONAL.
Select Backup & reset option.
Tap Factory data reset> Reset phone.
Select Erase everything.
When the warning window prompts, tap OK.
Hard Reset LG G2 with Hardware Keys
If you unable to perform a factory data reset on your LG G2/G3 using the device settings for some reasons, you can try the hardware key method. Just follow the steps given below:
Turn off your LG G2/G3.
Now press and hold the Power + Volume down buttons simultaneously for about 8 seconds.
When the LG Logo appears, release and then immediately re-hold the Power button.
Release the Power key as soon as you see the ‘FACTORY HARD RESET’ screen.
Press the Power key to reset your device.
Press the Power key again to confirm factory data reset.
Wait till reset is done.
Boot LG G3 /G2 into Safe Mode
To fix an issue caused by a 3rd-party app, you can boot your LG G3/G2 into Safe mode and delete the suspect app. You can turn on Safe mode by following these steps:
Jan 06, 2016 | LG Cell Phones
How do I do a factory reset on a SCH-R830C
Performing factory data reset ( master reset or hard reset ) Samsung Galaxy Admire 2 SCH-R830C via External Hardware keys buttons by Entering Android System Recovery:
  1. Turn off the device
  2. Remove the battery about 10 second and reinsert, remove sim card and sd card
  3. press and hold both the Volume Up key and the Power key until theSamsung logo is displayed.
  4. Press the Volume Down key to scroll to wipe data/factory reset.
  5. With wipe data/factory reset highlighted, press the Power key.
  6. Press the Volume Down key to scroll to Yes - delete all user data.
  7. Press the Power key to confirm.
  8. Press the Volume Down key to scroll to wipe cache partition.
  9. With wipe cache partition highlighted, press the Power key.
  10. Once the wipe is complete, press the Power key to select reboot system now.
Warning! All data will be erased from device memory, including system and application data, settings and downloaded applications. Back up your important data. The device will restore to factory settings.
Sep 19, 2014 | Samsung Cell Phones
Hard reset samsung sgh
Samsung T499 Dart Android hard reset
1. Turn off Samsung Dart. Press and hold Volume up key + POWER on the
phone. Reset
2. When the Android System Recovery screen appears, release the keys.
3. Using the volume keys, scroll down to Wipe Data / Factory Reset.
4. Press the Power key to confirm.
5. With Volume select Yes -- delete all user. Press the Power key to
confirm.
After master reset select Reboot System Now. Press the Power key to confirm.
6. Your T-mobile Samsung Dart phone reseted to the factory default state.
(This should work but if not, try both volume + power)
Samsung T-mobile Dart reset
A Samsung T499 master reset restores the original factory settings and
may erase all downloaded content, including ringtones, images, programs,
and contacts stored in the internal memory. It does not erase data
stored on the SIM card or memory card (if available).
To perform a hard reset, follow these steps.
Samsung Dart T499 Factory Data Reset
From this menu you can reset your phone and sound settings to the
1. Press Samsung Dart T499 reset - Samsung Dart T499 reset and then tap
Samsung Dart T499 reset settings key (Settings) - Privacy.
2. Tap Factory data reset. This action erases all data from your phone
except current system
software and bundled applications, or SD card files such as music or photos.
3. Tap Reset phone - Erase everything.
Samsung Dart Password code try 1234
or
Use this method to hard reset your Samsung Dart Android phone: Enter
*2767*3855#. Warning! All your data including contacts, messages etc.
will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM
or make backup to your PC before full reset! Take out SIM card before
full reset.
Jul 24, 2014 | Samsung SGH-T499
How do i factory reset on my SGH-A847?
  1. While in standby mode, press the right soft key for Menu
  2. Select Settings
  3. Select Phone
  4. Select Reset Settings
  5. Enter the password, using the keypad
    • If no password has been created, enter 0000
  6. Press the left soft key for Confirm
  7. Enter the password again to confirm, using the keypad
  8. Press the left soft key for OK
  9. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Note: The device will power cycle to complete the restting. All device settings will be reset to factory settings.
Jul 18, 2014 | Samsung SGH Cell Phones
Forgot mypattern to unlock phone its a concord zte768 I think can u help me
Try these steps:
ZTE Origin hard reset Master Clear/Reset Cricket Origin reset ZTE V768 ,
1. Make sure your phone has been powered off.
2. Hold down Volume up key and press Power key at same time until the screen lights up.
3. Press Home Key to access Android System Recovery screen.
4. Press Volume up\down key to locate wipe data/factory reset, then press Menu key to access factory data reset menu.
5. Select Yes-delete all user data, then press Menu key to confirm wiping data from the phone.
6. When finished, select reboot system now, then press Menu key to restart your phone.
Every data will be erased!
or You can reset your ZTE device's password: Turn off your phone, then turn it on. Select emergency dial. Input *983*987# in emergency dial-up pad. It will restore factory settings and your personal data will be erased.
or from the menu
Privacy: Reset to Factory Settings
1. Touch the Home Key > Apps icon > Settings > Privacy > Factory data reset > Reset phone.
2. Enter six zeros on the screen and touch Erase everything.
WARNING! All your personal information and downloaded applications on your phone will be erased after the factory reset. ZTE Origin V768 Phone Password A password can protect your phone and help prevent unauthorized use. When the phone is password protected, it will ask for the password every time the phone is turned on. Password protection is disabled by default, and the default password is 000000 (six zeros).
Jun 05, 2014 | Cell Phones
How do i reset my lenovo desktop to factory setting
If your Lenovo desktop is pre-installed with Windows operational system, press one-key reset key when your laptop is power off. Or press Shift + B to come back to factory setting instantly when Lenovo desktop is open.
Or press F2 when your Lenovo desktop is powering on. Few seconds later, a dialog pops up with several options, one-key reset and reset factory setting. Follow the operation wizard to reset factory setting is OK.
Related topic:
How to Factory Reset Samsung laptop?
Jan 01, 2013 | Lenovo Computers & Internet
How to reset samsung s w299
1 Find "Reset settings"
  • Press the Navigation key to access the main menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Reset settings and press the Navigation key.
2 info.png Restore the factory default settings
  • Tick the required settings by pressing the Navigation key.
  • When the box next to a menu item is ticked (V), the setting will be reset.
  • Press Reset.
  • Press the Navigation key to confirm.
  • Key in the phone lock code and press the Navigation key.
  • If it is the first time you use the phone lock code:
  • Key in the phone lock code again and press the Navigation key.
  • The selected settings are reset.
3 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
Key lock on
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
