Home | Canon | PowerShotŪ SD850 IS Digital Camera | Lens error , restart cam...
Canon PowerShot® SD850 IS Digital Camera
Problem for Canon PowerShot® SD850 IS Digital Camera
Lens error , restart camera
By nagosto on Jun 09, 2009
lens error , restart camera powershot SD850 IS
Solution #1
posted on Jun 09, 2009
Not Rated)
t00nz
Rank: Guru  Canon Expert Cameras & Camcorders  Expert
Rating: 91%, 1941 votes
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShotŪ SD850 IS
Questions and Unsolved Problems for Canon PowerShotŪ SD850 IS
Do you recommend Canon PowerShotŪ SD850 IS Digital Camera?
Answer
Answer
Lens error showing up on screen. The lens won't retract back in the camera
Answer
I have a problem with Canon SD850 in zoom mode and low light. Outside in less than sunny weather, if... (More)
Answer
Lens won't extend and retract when powerd on and off. LCD gives problem with lens notification.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShotŪ SD850 IS...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
