Question about Frigidaire PLHS69EGSS Stainless Steel Side by Side Refrigerator
Why will it not cool?
My fridge sat for a couple years without being turned on. still super clean though. when we turned it on it did not cool at all. fixed the fuse and other part that kicks on the condenser and it kicked on but still is not cooling. please help.
5 Suggested Answers
arikrom
  • 528 Answers
SOURCE: fridge isnt cooling
is the fan run on the compressor? you might need only starter unit to fix the compressor...
contact me at www.911servicetoday.com
Posted on Dec 30, 2009
SOURCE: not cooling, not freezing either
I assume you mean the compressor was replaced, the condenser is a metal coil, usually a black coated steel. You say the electric is working, so you have power to the unit and im guessing the lights are on..but is the unit running? If its not running, i.e., "it just stopped" its likely not the compressor. Could be one of several controls, or a wiring issue, or the previous servicer was not an EPA Certified Refrigerator Repair Service.
Posted on Apr 07, 2010
Macmarkus
  • 2605 Answers
SOURCE: I can hear the compressor
Welcome to FixYa.
I suspect by your description the fridge either has a faulty overload protector or the compressor itself is seized. Hence when the overload reset's the fan starts ( as it should when the compressor runs ) however the overload then trips and the fan stops while the compressor never starts, thus not cooling.
If you feel like you can trouble shoot further I`ll try to assist you or you may decide to call a professional appliance technician.
I don`t know the age of your fridge, but I should mention...
** Most of the Frigidaire fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to Frigidaire/Electrolux/White Westinghouse.**
If you have a multi- meter you can check the compressor to see if the windings are ok.
**First, Unplug the fridge**
Remove the panel at the back down at the bottom. This should gain you access to the compressor.
On the side of the compressor will be the start relay/overload assembly such as this image...it may be enclosed in a black plastic cover as well.
Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit.
i.e.
The above package contains info and hardware on how to connect it. HOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relide on for long term reliability or safety, but rather the factory replacemnet part 8201786... i.e.
macmarkus_95.jpg The above start device kit contains instructions on "how to" install kit. Hope that help`s move you forward if nothing else. If so please take a second and rate the reply and a testimony to your inquiry you received here at FixYa.
Thank you and good luck.
Regards,
Macmarkus :)
Posted on Dec 20, 2010
imufo2
  • 3773 Answers
SOURCE: When the condenser kicks on
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Sep 11, 2011
Refridgertor is not cooling dometic rm2804
If the fridge is level and the rear coils of the cooling unit get warm and the fridge does not cool then you require a replacement cooling unit. Yours has leaked. Contact ArctiCold Refrigeration We keep it cold Online store: http://www.rvfridgerepair.com/ 60f363ae-5e9d-402e-98c8-b8fed71c2461.jpg
Jun 23, 2013 | Dometic Refrigerators
Model ZHSC02PP-- Mini fridge no longer cooling (18-24 months old)
Has it sat any amount of time without usage? Check and see if any of the 4 walls is cool, it could be that the fan isnt working.
Jan 30, 2012 | Haier Refrigerators
My Hoover Nextra fridge freezer is 9 years old in perfect condition. Fridge has stopped cooling but freezer is working ok. I have turned up temp control to super, motor is warm but silent. What could have...
Hi, I have a Hoover Nextra Fridge Freezer and last night it tripped all my electric. When I plugged it back in, it sounds like it is starting, but then after a couple of seconds clicks off again. Any ideas?
Dec 26, 2010 | Refrigerators
The freezer is frosting up on my Whirlpool Gladiator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 02, 2010 | Whirlpool Gladiator Refrigerator
Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Oct 19, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
GE Fridege TBX18J MS not getting cold
hi is the fan motor going in the freezer. if so how long has it been plugged in if more than 24 hrs and the fan is going. it could be that because it sat for 10 years the lines that go inside could have rusted out. so if this is the case its scrap sorry. the appliance doc.
Oct 16, 2008 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Sep 23, 2008 | Liebherr Refrigerators
We bought a whirlpool gold fridge side by side a year ago. Lately, it has had some problems cooling both the fridge and freezer. We used to keep both of them on 4 or 5 setting, but now, even on 7 we're...
If fridge is not cooling enough see the reccomandation below from Repairclinic:
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Sep 07, 2008 | Whirlpool Refrigerators
Cooltech super xflow not circulating
hi
there is problem with x flow motor which is located inside the ref temp. assy. in frige section.this problem dosen't affect the cooling of fridge.this problem can resolved by replacing the x flow motor
yours
sandesh
May 15, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Frigidaire PLHS69EGSS Stainless Steel Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
