Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissel Proheat steam cleaner. Won't move forward. Brushes spin, belts not broken or jammed.
SOURCE: Bissel Proheat Carpet cleaner
My Bissell had the same problem. The hand attachment does not use heated water. So I Found a clog of calcium and dirt in the heater portion of the unit. The heater is in the handle behind the red heater light on the front. Remove the upper portion of the handle. Remove the lower two screws in the lower portion and the parts will split apart. Remove the hoses and remove the heater. (mark where the wires go) The bottom of the heater can be removed with a screwdriver. The tubes leading into the heater is where the clog was but there was a lot of debris inside Make sure to clear it all and the hoses as well. I put it together and it works great.
Posted on Nov 25, 2007
SOURCE: Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Posted on Jul 14, 2008
jyackle5
  • 8197 Answers
SOURCE: belt manual
Here is the manual. on page 17 tells you how to change.
http://dl.owneriq.net/2/23cae7f7-686f-47c1-8efe-3a106fffcd50.pdf
Good Luck and Please Rate FixYa!
Posted on Jan 11, 2009
  • 33 Answers
SOURCE: My power brushes on my
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Posted on Jan 18, 2009
  • 29 Answers
SOURCE: I used my new proheat 2x steam cleaner the first
You may have mislaid a piece when you took your Bissell apart to clean it after using it the first time.
I experimented with mine to try and reproduce your issue. On the bottom of the water tank, there are two pieces that can be removed from it. One of them looks like a black plug at one end, with a red rubber flange piece on the other end. If you push your finger inside the red rubber piece, you can feel a spring move up and down. This is the first piece you place on the bottom of the water tank. I suspect you have this piece, because if you didn't, water would gush out of the water tank as soon as you turned it over after filling it.
The other piece, which is the one I think you may have have mislaid, is a larger black, plastic ring with screw threads. This piece goes over the top of the first plug piece, screws onto the water tank, and holds the plug in place. The words "RECLOSE TIGHTLY" appear on mine. If this piece is missing, the water tank does not sit flat on the base of the Bissell, but kind of flops around, out-of-place, and the unit will not dispense water properly, though it may leak it.
If ithat piece is gone, it should be possible to reorder it. Start here:
http://www.bissell.com/Customer_Service.aspx
If that's not the problem, if you have all the water tank pieces, I wonder if perhaps you unscrewed one black screw to remove the clear front plastic piece from the base of the unit-- the piece through which water is drawn up off the carpet-- to clean it, and didn't get it back into place properly. Make sure the two hooks at the bottom of this piece are inserted, one per side, into the clear plastic side pieces at the bottom. If the hooks are not secured properly, before trying to reinsert them, unscrew the black plastic screw so you don't break the tab. It's easy to miss getting these one of those hooks back in right, but it's important to do that before trying to screw the clear front plastic piece into place.
Posted on Jun 12, 2009
Brushes aren't turning on Bissell Proheat 2X and it is almost new.
New or old,flip the vacumm over,and remove the long hair and debris from the roller brushes. If they don't spin after removing any debris,the
belt,that turns the brushes has come off,or the motor is bad. You wil
have to take the bottom section apart,to see what's going on,then.
Good luck.
Apr 01, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to get the beater brushes to work
Your belt is broken or has come off the track.
Mar 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brushes stopped spinning
Usually that the belt has broken, turn it over and see if the brush rods turns freely.
There are two belts, one that conects the two rods together, one that drives them. if they both still move together, then it is likely the big belt to the motor. If one moves freely and the other one harder, then likely the belt between the two.
Your manual tells you how to replace them. Can also be found at bissel.com.
Peace
Mar 04, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel pro heat cleaner won't expell water -- seems no suction
The reason that it won't expel water is because your pump belt is stretched and worn. You need to replace that belt, it is pretty easy. Here is the belt you need:
Bissell ProHeat Pump Belt
Jan 30, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Brushes don't spin and not picking up water
Depending on your model, the belts may be worn or broken. You can get replacements here:
ProHeat Replacement Belts
Nov 07, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a bissel 7920 proheat pro-tech machine but it does not spray water and shampoo
sounds like a pump problem. PIC << click
heres a website that sells it << click
i would also replace the pump belt.
other things to check
tank may not be seated properly.
pump belt may be broken.
filter maybe clogged.
Oct 08, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
No cleaning fluid or water comming out of cleaner
not sure of your model but on most of the bissell's ( except there new style) the belt drives the pump and the brush on the bottom. no pump action then no spray action. you probably need a new belt.
Sep 03, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
Brush belt is very weak.
Brush Belt broken or disconnected. Very weak belt. Colossal engineering mistake by Bissell. Belt itself and its components are under way to much stress for the size they developed to perform their task. For Quality Control to let such an obvious blunder pass can only mean that it was intentional for reasons, Im sure, beneficial to Bissell and costly for the consumer. No telling how many people buy another entire machine when this rubberband of a belt breaks like it was intended. Bissell is not a consideration of myself or anyone I can enlighten.
Apr 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
42 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
