Question about Necchi 4595 Mechanical Sewing Machine
Can't turn wheel
Wheel stuck
Check the area that contains the bobbin. There might be something loose in there. While you\'re in there, clean an oil this area. Also, open the end cover (left side of machine) and lubricate the swivel arm top and bottom and wait overnight for oil penetration; you can also use a hair blow dryer to speed this up. For oiling diagram, see:
http://sewing-machines.blogspot.com/2009/11/necchi-zig-zag-issue.html
Posted on Aug 07, 2014
Hand piece is very tight to turn and unable to use the machine
Make sure to clean/remove all the lint, thread, dust, etc. that may have built up in the bobbin area, around the feed dogs, and under the needle plate. Sometimes gunk build-up will prevent the hand wheel from turning. Remove the bobbin & bobbin case from the machine and the needle and see if the hand wheel will turn. If not, then it may be time for service.
My hand wheel is hard to move and will not make complete turn unless...
https://answers.yahoo.com/question/index?qid=20100518074139AAeeykz
Help My Needle Hand Wheel are Stuck Sewing Machine Jammed
Apr 20, 2016 | Sewing Machines
My hand wheel will work manually going backward but not forward
then the machine needs to be taken to repair shop and timed bobbin and needle are not in sync anymore
Oct 21, 2015 | Singer Sewing Machines
My bother power sewing machine has lock up the wheel will not turn
Try to turn the hand wheel backwards possible thread stuck on the needle hook by the bobbin. Take the bobbin out and remove the face plate and clean machine.
Jan 31, 2015 | Sewing Machines
The hand wheel is stuck and won't move. machine makes a vibration noise
try working it back and forth it might jst be stuck a little but vibrating might mean you are putting it out of time too.
Jan 19, 2015 | Brother XR9000 Sewing Machine
What do I do to unstick the wheel on my singer 4423.CL - heavy duty sewing machine?
possibly you bent the wheel and has to go to the repair shop to replace .
Nov 14, 2014 | Singer Sewing Machines
Turn wheel not turning easy
Hand wheel "stuck" because you have an obvious jam. Remove bobbin and clean bobbin case, put good quality sewing machine oil on oscillating hook and put new needle in flat side toward back all the way UP, and make sure presser foot UP when you thread machine. Jimmy
Apr 07, 2012 | Brother Sewing Machines
The machine froze as I was using it. The wheel cannot be turned and the needle will not move. It is like the motor froze on it. Can it be reset?
You might try other solutions; however, this works for me:
The needle is bent or stuck.
1. Loosen the needle thumb screw
2. If the needle is stuck then that was the problem, the turn wheel should work ok.
3. The bobbin may be damaged as well.
If this doesn't work, then I'm afraid you will have to "force" the wheel. It is not the motor.
Does the motor make a noise like it is trying to work?
Hope this helps!
Sep 03, 2009 | Sewing Machines
Needle position wheel is stuck
Remove the top cover. Note where the shaft of the the needle position wheel enters a metal casting under the wheel. Old oil deposits gum up the shaft. Heating this area with a hair dryer usually frees up the shaft. Be careful you don't use too much heat that would melt the plastic wheel. Lubricate the shaft with tri-flow and work it in by turning the wheel while it is warm. If it sticks again after it cools, repeat the process. It may take several hours or days for the tri-flow to penetrate and free the wheel up.
Advice provided by the amazing Ray White at whitesewingcenter.com
Jul 07, 2009 | Elna Sewing Machines
Hand wheel is stuck
hi there,
well,stuck up hand wheel, is due to mechanical obstruction inside machine,bushing on shafting need to oil,and on handwheel bushing near clutch there is oil port there. since hand wheel are connected to cam shaft with set of gears and pulley is coupled to motor pulley,and other linkage under bobbins,shuttle race etc,broken gears are most common causes of stuck up handwheel,we can consider also the brush carbon,when worn out and damage the rotor commutator brush.if you can open the cover of motor below side of handwheel,you can see the pulley and motor assembly.also on top of machine there an opening to see the top gear assembly,this should be done by service technician.try to bring to nearest service center if still under warranty claim this for lesser maintenance cost.have a nice day,don't forget to rate me.thank's.
Apr 20, 2009 | Sewing Machines
Wheel won't turn
The same thing happend to me with an older model (Singer XL 10). I have been sewing a decorating stitch and the machine stopped suddenly. Now I am not able to turn the hand wheel anymore like I should (I can move it a little bit, but the needle does not move up and down and the wheel is getting stuck). When I try to use the pedal the motor makes a horrible noise and stops. The needle is not moving up and down.
Is there a solution for that problem? I moved from Europe to Australia and have not used my machine since. Today is the first day, I was cleaning and oiling it and it first sewed perfectly. In case that there would be thread stuck somewhere, how could I possibly clean that? I already took off the plastic from the head, but I can not see where the problem is.
Any help is appreciated. Thank you!
Best regards,
Nelly
Jan 12, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Necchi 4595 Mechanical Sewing Machine Logo
83 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
