Question about York Exercise & Fitness
Rethread belt the belt came off thehand rail and flew back inside the machine. How do I correctly rethread it through, as I thought I had done it correctly be the resistence is not the same.
Left screws in the back of new Zanussi washing now it wont spin
It must have broken some plastic off inside or may have jammed the belt mechanism. Check the belt and suspension/mounting.
Jan 16, 2014 | Zanussi Washing Machines
Hi I have a BEKO WM5100W washing machine.The drum doesn't spin,I have replaced the brushes,went to apply belt on the back of the drum and discovered there's no movement there to apply belt where there was...
Are you saying that, previously, there was a part with which you could attach your belt on to the machine, and now that part has gone missing? As in perhaps it broke and flew away into a corner somewhere?
Or are you saying the machine has never used a belt and you are just now finding this out because this is the first time you've gone mucking about in the back of the machine?
SUGGESTIONS:
1.) Check power cord
2.) Do lights work when machine is plugged in?
Nov 30, 2013 | Washing Machines
Need to know how to replace belts on a Sanyo RD R60 Stereo Cassette deck circa 1987
Well these machines are not always easy to put parts into and there are some things to do that are not written in the manuals even if you get them. Often times the transport has to come out of the unit and then brackets and motor plates have to be removed to access the belts. This is just the reality of the job and why it can take so much time to do it. Just replacing belts in a machine does not guarantee that the unit will work well just from those belts. New belt will allow the torque to be transferred but the speed of the motor still needs to be set and wow and flutter measurements to determine if the deck is usable. Some belts of the wrong type will result in high wow and flutter. It depends on oiling and belt tension and if the reel torques are correct.
The real answer to your question is not how you put the belts in but that you need to have it worked on my a Technician who knows what they are doing. Most deck owners are not set up with experience or equipment to get the correct job done.
Jul 29, 2012 | Audio Players & Recorders
Clunking noise when sewing flannel new machine
try changing the needle
clean under the needle plate for lint, flannel has quite a bit of lint
make sure the bobbin is turned the correct way in the bobbin case
try rethreading the machine top & bobbin
May 06, 2012 | Brother XL3750 Mechanical Sewing Machine
I have a brand new 4423 that is frustrating me so much I'm tempted to return it and buy something else. It will not sew a seam without having "birdnesting" underneath. It's horrible!! ...
Take it back while its under warranty and ask the dealer to thread up and sew on it; this way you can establish if it is a faulty machine or if its some other variable causing it. Certainly if you are an experienced sewer and have used other Singers, then you would know if you've done it correctly and your instincts tell you the machine is faulty so I'd suggest you take it back to the store.
Oct 03, 2011 | Singer 4423 Sewing Machine
On a brother cs 8060 - as i pushed the thread compartment into the machine a silver metal forked thing flew off the machne hitting me in the neck. it has two pins one on each side and is actioned by a...
the piece that flew out goes to the piece that lowers with the wire. mine is having same issue but i saw mine right before it flew off. not quite sure how it goes back together.
Jan 07, 2011 | Brother CS-8060 Computerized Sewing...
My sewing machine is not working properly - i think i have loaded the bobbin correctly but after about 3 stiches the cotton all jams - what have i done wrong - it is not a new machine I have used it before...
put a new needle in the machine
clean under the needle plate where the feed dogs are for lint
clean in the bobbin area for lint & loose threads
also rethread the machine, make sure you get every thread guide
Nov 18, 2010 | Janome SEW MINI Mechanical Sewing Machine
My needle on my Esante seems to be hitting something the skipping stitches. I have changed needles, rethreaded, changed plates, and changed feet. Thanks
Did you thread the machine with the presser foot up? Is the needle inserted with the flat side to the back of the machine?
If so, and the problem has not changed, check the bobbin case to be sure it is correctly placed into the race. Leave the needle plate off as you hand walk the needle down. If it hits the case, it is not in place.
All the above has been done and problem continues, take the machine in for service as the timing may need adjusting and is a process best done my an authorized Brother dealer.
Mar 11, 2010 | Baby Lock Sewing Machines
Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
Jun 08, 2009 | Singer 2639
Machine wont pick up bobbin thread
hi,try loosening your needle and pull it down a fraction then tighten it back up,i had same problem,good luck
Mar 11, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Exercise & Fitness Logo
37 people viewed this question
Top York Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
ray gallant
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
