Question about Epson - PowerLite S1+ Multimedia Projector
Image is upside down - Epson - PowerLite S1+ Multimedia Projector
2 Suggested Answers
son-of-EP101
  • 24 Answers
SOURCE: my projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Posted on Apr 12, 2010
Why when I look through my telescope it's upside down
The image in astronomical telescopes are naturally upside down. This can be corrected using an inverting eyepiece . The reason this is the case, is that normally when viewing astronomical objects it doesn't matter if the image is upside down, so to minimise the loss of light that is the more important issue, unnecessary optical surfaces are eliminated. Terrestrial telescopes do naturally have inverting eyepieces as people expect to see objects the right way up.
Getting and inverting eyepiece will be cheaper the changing telescopes! :) Your eyes see everything upside down too, but your brain turns the image the right way up. The image in cameras is also upside down at the image plane, but the electronics turn it the right way up for you.
Jan 02, 2015 | Optics
Why would the images be upside down
All astronomical telescopes show the image upside down. For terrestrial use, you need a erect image prism.
Jun 01, 2014 | Tasco Optics
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
My projectors image is upside down. how do i fix
Apr 11, 2010 | Epson EX30 LCD Projector
How do I get the image to turn the right side up? When we first set it up the image was right side up for a few minutes and now it is upside down and we can't figure out how to get it to flip. The image is...
Dopn't worry about upside down. All astronomical telescopes show images upside down. There is no up or down in space.
You may have what is called an "erecting" prism diagonal that turns the image right side up. Just Google "erecting prism diagonal".
This may also help you.
http://www.cloudynights.com/item.php?item_id=810
Dec 27, 2009 | Edu-Science (10166) Telescope
Everything is upside down
Astronomical telescopes produce an upside-down and reversed image (image is rotated 180 degrees from an upright position) since this doesn't matter when you are looking at things in the night sky. Accessories are available for rotating the image to an upright position, but most of those accessories do not work well with Newtonian style reflector telescopes such as the 114EQ reflector.
Jun 26, 2009 | Meade Infinity 114EQ-DH Telescope
How do I correct an upside-down image?
Normal 0 Try this, while the computer is running, unplug the camera from the USB Port , wait a few seconds and then plug it back in. I have fixed several cmaeras that were upside down that had the same problem by doing this.
Worth a try.
Hope this helps. Bud
Mar 24, 2009 | Computers & Internet
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Epson - PowerLite S1+ Multimedia Projector Logo
22 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
