Question about Edimax Computers & Internet
Isp username and number of smartbro version 5.244
CANT ABLE TO CONNECT DIAL UP CONNECTION
Turn on your computer. Click the Start menu, go to the Control Panel and access "Network and Internet Connections." Click the "Create a New Connection" option in the upper left corner of the window. Click "Next" until you reach a list of options. Select "Connect to the Internet," and click "Next" again. Select "Set Up My Connection Manually," and click "Next." Select "Connect Using a Dial-up Modem," and click "Next." Enter a name for the new connection you are creating (e.g. "Dial Up Connection"), and click "Next." Type in the phone number you will be using to connect to the Internet, and click "Next." This phone number will be provided to you by your ISP. Enter the username and password provided to you by your ISP. This will successfully configure your Internet connection. Plug a phone line into your computer's dial-up modem. You may now use the newly-created connection to connect to the Internet. b> Macintosh Computers Turn on your computer. Access the Apple menu and click "System Preferences." Click "View," and access the "Network" option. Click on the "Show" pop-up menu and find the "Internal Modem" option-or the "Configure" option if you are not running Mac OS X 10.5-and click it. Click the "Configure" menu if you are running a version other than Mac OS X 10.5. If you are running version 10.5, select the "PPP" tab. These options will both have the same result. Enter your information into the appropriate fields in the new window that appears. Your ISP username goes under the "Account" field, and password under the "Password" field. Save your preferences when you are finished. Plug your phone line into the modem jack on your computer. Your computer will now be able to connect to the Internet via dial-up.
b>
Feb 06, 2013 | Acer Aspire Computers & Internet
How to load my smartbro prepaid kit?
hi there!
loading your SmartBro prepaid kit is like loading your cellphone. just go to your prepaid loading store and give your number and the amount.
Hope this helps
May 17, 2011 | Computers & Internet
D-Link Wireless-N GigaBit Router(DIR-655) using SmartBro Broadbnd
first of check for the ip address of D-Link wireless. Then try to open it in the internet explorer. give the username and password. then go to wireless option and select the security protocol wap or wep. Provide a network password. Set the DHCP range and save & exit and restart the wireless. Then try to ping from ur pc
Apr 19, 2010 | Computers & Internet
All the lights on my Westell Model 6100 are green except the internet light is red. What does that mean? Thank you!
The reason why your internet light is red for the westell model 6100 is because it is not yet configure. You need to access the gui of this modem. Enter the username and password for your internet connection. You will get the username and password from your ISP. You can contact your ISP provider so they can walk you through for the steps on how to configure your new router.
Apr 06, 2010 | Westell Wirespeed LiteLine 6100...
How to configure this router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. Since your ISP is Smartbro, first connect your laptop or computer directly to the smartbro modem, check if you have internet connection, if you have, click on start, then run adn type in cmd, it will pop up the dos prompt, type ipconfig/all. It will list the ip address, subnetmask, default gateway, dns server. write it down on a piece of paper.
b. access the setup page of the router and on the internet settings, manually set it to static ip address.
enter the ip address, subnetmask, default gatewat, dns server.
c. then the smartbor modem should be connected to the WAN port of the router and your computer should be connected to the port 1 or port 2 of the router.
d. if you want to connect on a wireless connection, on your router you need to setup the wireless connection setting.
if you have any query pls feel free to get in touch.. good luck
Dec 04, 2009 | Encore ENRTR-104 Router
Router cannot connect on internet at setup wizard
Hi pag Smartbro ang gamit mo hindi mo pwede gamiting ang setup wizard. Iba kasi ang paraan ng connection sa SMartBro. Mahirap explain it would be best if you call Linksys Philippine support since there are so many ways to connect Smartbro to a Linksys router. The number is 1-800-1-114-1695 toll free. or kung gusto mo sa Yahoo ID ko nalang mastersaintx message mo ko sa umaga.
Sep 03, 2008 | Linksys Wireless-G WRT54G Router
How to use edimax br6104k with an smartbro isp
It's not a problem connecting to internet if your isp is smartbro, esp. if you are using a D-Link router..just plug in ur smartbro rj45 to the WAN port and connect ur pc to one of the 4 LAN port of the router that's all you can connect to internet..first time of course u have to input the username and password from smartbro in order to connect again..
May 20, 2008 | Edimax BR-6104K Router (br6104k)
I help some help
Were you able to fix the problem? I am experiencing the same problem too.
Mar 21, 2008 | Computers & Internet
Edimax br-6104k
do you have apppoe connection or dhcp? release your ip address (ipconfig/release) set your modem to bridge mode then connect modem and router. try to connect.
marlon
Jan 16, 2008 | Edimax BR-6104K Router (br6104k)
Computers & Internet Logo
16 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
