Question about Refrigerators
HSS25GFPH Refridgerator getting too cold. Manually closed the damper, but later found it wide open again. Is it the thermistor?
  • 958 Answers
SOURCE: side by side not cooling ref side damper closed
if your damper motor is not functioning, then it could be one of the following.
the damper motor itself, the thermostat ( the controller),
or the thermistor ( the temperature sensor).
either one of this is bad, then the damper will not work.
bring down the damper motor and check the voltage requirement of the motor. bench test it if you can to determine if it is still working.
test the thermistor for resistance. immerse it in ice cold water and watch the resistance change. if you do not have a reference value, then it may not tell if it is good or bad.
the electronic controller would be a hard thing to test.
if you have the book and it has diagnostics , then run the damper control test to test the controller.
tnx 4 using fixya,
drcool
Posted on Sep 30, 2008
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
  • 5370 Answers
SOURCE: have kenmore 253.54622402 side by side--from the
" waited 1 hour freezer 20 degrees // cold food side 45 degrees and no air flowing from damper " As per this it indicates that the ventilations are getting blocked after few hours.First the air was flowing from damper but after one hour it stopped flowing air from damper.Check the damper if there is too much water collected in the damper then press the damper and remove the water collected in it.------------ The working procedure of this Kenmore side by side refrigerator is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fresh food section gets cold. The air from freezer to fridge passes from the section, in that section the damper is located. Now this problem which you mentioned. In this problem the freezer thaws, this happens if the thermostat is not functioning or the heater is not heating. Then the ice starts getting collected on the evaporator coil. The evaporator coil is at the internal section of freezer. If too much ice gets collected then this ice blocks the fan in the freezer section from functioning and this blocks the damper section with ice getting collected there. This all procedure is controlled by the main defrost board of the unit. Now if the damper is not got blocked with too much water or if the ice is not got collected on the damper area then check the evaporator coils. If there is too much ice got collected on the coils, then takes a hair dryer and melt the collected ice. Then see if the problem returns again. But if there is little bit ice collected on the coils and fan is running properly then it's not a problem. In that case main board is faulty and it has to be replaced. The main defrost board is working but its not controlling the functions as required so the freezer thaws after few hours.
You can get required parts from sears part direct online site or from repairclinic.com site.
To test defrost thermostat you can test this way:---
The defrost thermostat is difficult to test since many refrigerators use different fixed temperature settings and unless you have a very accurate temperature test device the test will not provide proper results. Now you can take the defrost thermostat out of the unit and place the element only in a glass of ice water. When the element is cold it should have continunity between the two wires.------ The meter should not show a reading if the thermostat is turned off. If a reading appears, replace the thermostat.
When the thermostat is turned on, the meter should indicate "0" ohm or .3 or .2 on a digital readout. If it does not appear as "0" ohm or .3 or .2, replace thermostat.Turn the thermostat on and place each probe on either side of the thermostat so meter reads "0" ohm or .2 ohm digital. Put water and some ice in the cup. Temperature should be 32 degrees. If, after four minutes, the meter does not reflect infinite or .0000 on the digital meter open circuit, replace the thermostat.----If thermostat checked out ok then check defrost heater connection.The defrost heater is connected to the side of evaporator coil in the freezer section.If this defrost heater is faulty then it will not melt the ice getting collected on the evaporator coil and due to that defrost system will not be able to function as required.Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.-----------
Now to see where defrost heater is located.Please click on this link below and see part number 14 on the diagram.And part number 15 is evaporator coil.And part number 21 is thermostat.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/R0405135-00006.png
This will help. Thanks. Helpmech.
Posted on Jan 20, 2011
bobicehouse
  • 1524 Answers
SOURCE: I have a GSL25JFPA BS that the frig side will not
Unplug the refrigerator and then plug back in. Using multimeter check between J3-1 and J3-4.
Must be done within 10 seconds of starting. You should have 6 VDC. If you do replace damper, if not replace motherboard.
Posted on Jul 06, 2011
  • 5370 Answers
SOURCE: Kenmore Freezer works, Refrigerator doesn't
As per the problem, it does not indicates towards compressor problem.Because idf compressor stops working, then freezer section will not freeze.But in your case the freezer is working properly, so this clears that compressor is working properly.--------- As per your problem, its defrost problem.--------
The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site.------------ As you mentioned that defrost heater and defrost thermostat both are working good.Then problem indicates towards defrost board.------------------ -------------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.---------------------
NOW read this point carefully. When the freezer reaches its cooling level the defrost cycle starts functioning.---------- But when freezer section reach the set temperature, then thermostat senses the temperature and give command to defrost board that , now start the defrost heater.So defrost heater gets hot and melts the ice.The ice melting water in the freezer section, drains from the drain line to the pan above the compressor.This drained water gets dissolved in air when compressor gets hot.---------- But in your case most probably the thermostat is not sensing the freezer temperature, so the defrost cycle is not starting and if defrost cycle will not start, then cool from freezer will not get to the fridge section.--------- So most probably its thermostat, but if thermostat checks ok, then its faulty defrost control board.--------- For getting thermostat testing instructions,click the link below:--- http://howtobyme.blogspot.com/2011/07/how-to-test-defrost-thermostat-on.html --------- This will help.Thanks.Helpmech.
Posted on Jul 18, 2011
Samsung rf217acrs freezer is not freezing
would check ur freezer thermistors and cold control thermostat as well as air flow damper vent
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
Aug 14, 2014 | Samsung RF217ACRS Stainless Steel 20 Cu....
Freezer side not freezing but refridgerator side is cooling
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required
Jun 12, 2014 | Samsung RS2630SH Side by Side Refrigerator
Why does my freezer stay steady at 28 degrees will not freeze well, refridgerator seems to still work. Nothing appears frozen, or clogged. Is it the fan, or something else?
THERMISTORS in the
Jun 06, 2014 | Samsung RS2630SH Side by Side Refrigerator
Samsung rb215labp freezer cools but refrigerator wont cool
May 28, 2014 | Samsung RB215LASH
Refridgerator not cold in RB2055 model
May 16, 2014 | Samsung Refrigerators
Ge refer model psc25mstass fresh food section not cold enough freezer cooling fine
I realize this is an old post but information is always helpful if it is correct. I have a GE Model TFX22ZRB, Main tools needed are a refridgerator thermometer, a cheap multimeter, 1/4" hex driver, phillip screwdriver and regular blade scewdriver, above all, alow time for tempeture change when measuring tempeture. The freezer is running at -8 degrees C or aproximately 28 degrees F. I don't care about 1 or 2 degrees at this point in the freezer, the defrost system is working ok, The freezer is cold enough. The fresh food section is running at 48 degrees F, the damper is wide open between the freezer and cold food section, I manually removed the damper door and controls since I am only interested in seeing if I can drive the fresh food section colder. Looks like the fresh food thermostate controls the compressor and not the damper to shut off the cooling process when the tempeture gets cold enough. Since the fresh food section does not get cold enough (this should be in the uppers 30s F) there is no need to move the fresh food thermostate out of the normal range setting (mid point in my case) with the operator control. Defrost heaters ok, this unit uses 2 heaters hooked in series with a evaporator coil thermostate also in series with the heaters. Heaters aproximately 25 ohms total risistance, coil thermostate open at room temp and closed when below 32 degrees. Only other item in circuit is the defrost timer, this can be manually advance to open and close the defrost circuit, in my case, when in the defrost mode, the evaporator fan stops and the heaters heat up. The defrost timer in my case has a 12-16 hour cycle time and a 30 min defrost time, so in a 24 hour period I may get only one defrost cycle. One item of importance. make sure something has not fallen in the lower back or the fresh food section of the refridgerator to block the air flow return, this will effect the coo;ing process. Now with the damper wide open, the defrost circuit working ok I am going to look at the evaporator fan itself for speed, shifted blades or the air circulation between the freezer and the fresh food section, I have cleaned the condenser coils but I am leaving the condensor and compressor out of the equation since the freezer is cold enough but at this point I am considering the possibility, I may need to replace the fridge if the compressor is not working to par.
Jul 18, 2012 | Refrigerators
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side not cooling ref side damper closed
tnx 4 using fixya,
drcool
Sep 30, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Fridge too cold
There is a damper motor that is behind the vent where you feel the cold air coming out in the fridge section.  That damper should open and close after making temp. adjustments.  See if you can look in the vent and see if it is wide open.  Set your freezer on the coldest setting and check this vent again an hour or so later.  If it is still wide open then that damper motor is bad.  Let me know if you find something different or have any questions.
Oct 10, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
