How to replace transfer belt on a KYOCERA FS-C5350DN COLOR
How to replace transfer belt on a Unit KYOCERA FS-C5350DN COLOR LASER PRINTER/
  • 40 Answers
SOURCE: 6000 error on a Kyocera
a fuse it is blown within the FUSER UNIT - replace that fuse or call a technician to do it for you.
Posted on Jan 10, 2009
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
SOURCE: Lexmark C522n Laser Printer stating "83 replace transfer belt"
how do you reset the transfer belt of a Lexmark C522 colourlaserjet.
Thanks
Alex
Posted on May 10, 2010
SOURCE: I can't get a drive for laser printer kyocera fs
http://kyoceramita.com.au/fs720.asp has xp driver for fs-720
attach fs-720; windows 7 will recognise but fail to install
click on 'unspecified device fs-720' in devices and printers
click to upgrade/install driver
use driver specified above (xp)
should install properly
cheers
Posted on May 20, 2010
What does a c4203 code mean?
More than likely you have a PDF Owner's manual on the Software install disk. It should have troubleshooting section to help you with this and any future issue. The software may also have a trouble shooting system.
I googled and this seems to be a possible answer:
http://northeastprintsupplies.com/images/FS-C5350DNENSMR1.pdf
May 14, 2015 | Kyocera Mita Ecosys FS-C5350DN - 32PPM...
Where do I load paper in a Kyocera FS-C5350DN Full-Color Laser Printer
At the bottom of the printer you will find the paper cassette. Pull the handle and the cassette will slide out. Eventualy you will need to ajust the size of the paper.
Jun 23, 2014 | Kyocera FS-2000D Laser Printer
Kyocera FS-3920DN call service 2000:0011742
The call service 2000 is about the main motor. Pull the Developer Unit and then the drum unit out of the printer and check if the gears on both units are moving freely. Then turn the printer on without the 2 units and see if the motor is functioning. If your the motor moving then the message displays on printer will be 7410 (because you have the drum unit outside). There is a possibility that the transfer roller is damaged.
Mar 26, 2014 | Kyocera Fs-3920dn Laser Printer
Kyocera FS-1020D process unit in two pieces
best thing todo is get a new PU-102, the gap between the drum and dv unit is to large and the toner is not transfering.
Dec 27, 2009 | Kyocera Mita FS-1020D Laser Printer
How to remove Kyocera FS-2000D drum?
open top cover then pull the developer unit (toner box ) then open left cover remove the waist toner box ..... there you can find a Grey color lock push and pull the full unit
for manual send mail to anantakumarjena0@gmail.com
Nov 30, 2009 | Kyocera FS-2000D Laser Printer
Kyocera FS-1920 printer
this error belogs to temperture error
*replace the tharmister (white color componet it comes in fuser unit ) it will work
Mar 17, 2009 | Kyocera Mita FS-1920N Laser Printer
Kyocera FS 1010 printer. Not printing even with new cartridge
may be moisture.just switch the dehumidifier on for some tine.
Jan 18, 2009 | Kyocera Mita FS-1020D Laser Printer
Printer probs after replacing ink cart.
you probably scarred the drum for the cyan color. Replacing the drum unit will solve your problem
Sep 04, 2008 | Kyocera FS-C5015N Laser Printer
78 people viewed this question
k24674
jasbo
jasbo
