Question about Kenmore Washing Machines
Kenmore washer model 110 24992300, the tub. Water spilling over the tub
I have a kenmore washer model 110 24992300, facing problem that water in flow is not stopping and spilling over the tub. Can you suggest if I can fix it in my own? Is it something to do with timer?
SolutionGuy
  • 331 Answers
SOURCE: whirlpool washer model lsr8233eq1
Hi gastang,
The problem is with your water valve. It needs to be replaced.
To access the washer follow these steps...
UNPLUG THE WASHER!
1.) Remove the 2 screws from either side of the control panel.
2.) Pull the control toward you a 1/4", then rotate it up and all the way over.
3.) Remove the white plastic wire connector to the top panel (it has 3 wires in it.).
4.) Remove the two clips on either side of the top panel. Do this with a screwdriver. Poke the screwdriver into the top panel to engage the clip, now rotate the screwdriver toward the rear panel.
5.) Lift the lid (for a hand hold) and rotate the entire cabinet forward to about a 45 degree angle then slide it toward you. Set it aside.
Here's a video that shows how it's done. But you'll notice that the screws on your control panel are in the front, the video has the screws in the back, but the rest is the same. Here's the video.
After you have access, you'll see the water valve on the right.
If this was helpful, would you take a moment and rate my solution? Thanks,
SG
Posted on Mar 29, 2009
localwonder
  • 6784 Answers
SOURCE: Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Posted on May 31, 2009
  • 351 Answers
SOURCE: Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
Posted on Jun 24, 2009
  • 3230 Answers
SOURCE: I have a kenmore washer 700 series. Water is
Yes its true that this washer not worth repair.... Better you can go for a new washer..
I have a question - is there any error code on the display control?
thanks
Posted on Jul 07, 2009
beltronic205
  • 1461 Answers
SOURCE: GE Washer Wont Fill
Make sure drain hose not too low , creating syphon...
Posted on Jun 01, 2010
Testimonial: "After posting this question I saw something on the internet suggesting the same. I think this must have been the problem. Thanks for your help!"
Kenmore washer frontloader model 417.41122410 code E11
An E11 error indicates a problem with the incoming water. The error will occur if the tub doesn't fill normally in about 8 minutes. This could be related to closed shut-off valves, failing anti-flood hoses, or debris in filters in the hoses or at the inlet valve on the washer. It could also come from a fault with the sensor that detects the weight of the washer tub, a problem with the reed switch that tracks water flow into the washer, the air tube that goes to the reed switch or a failure of the inlet valve. It can even indicate that the end of the drain hose is below the water level in the washer and is siphoning water out as the tub fills.
If no water or a trickle of water is reaching the tub, first make sure that the shut-off valves are open. Next close the valves and disconnect the hoses. Place the hoses into a bucket and check the water flow by opening the shut-off valves. Shut off the valves. Clean the filters, including those in the inlet of the washer. Reconnect the hoses or replace them with new ones if there was low flow. (Check the flow at the shut-off valves themselves with a similar bucket under the valve opening, if you can.) If these steps don't work, you need to replace the inlet valve assembly. It failed in the closed position.
If water is filling the tub normally and flowing out the drain, check the drain hose position. If the tub is filling and is held in the tub, then the washer isn't correctly measuring the water flow. Check the reed switch and that tubing by blowing into the tube. Replace a faulty switch and remove any blockages from the tubing. Check the wiring harness to ensure that the message got to the control board.
See http://www.searspartsdirect.com/model-number/41741122310/0582/0153200.html for parts diagrams and price lists. You need the control panel diagram.
I hope this helps.
Aug 15, 2017 | Kenmore Washing Machines
Should I be able to see water in the tub of my Kenmore 796.4027 washer?
different machine
the water spurts are operating as the drum rotates so that the clothes are evenly wet before the wash process begins
could be designed to use less water than previous models
make sure that the drain hose is at the correct level or all of the water will drain out
talk with a service agent and read the user manual for the operations and what can be expected
Apr 17, 2017 | Kenmore Washing Machines
Water large amounts on floor of shut off machine
To sufficiently inspect your washer to determine where to leak may be coming from, please review the following link:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
If there is a huge gush of water coming from the washer as soon as you begin the fill cycle, this is commonly caused by a small air hose on the side of the washer drum that connects to the pressure switch. If this air hose comes loose,the water will pour from the wash tub as it begins to fill. This is an easy fix, if that is the only problem.
Another cause, can be a water inlet valve that is leaking by, or a pressure switch that does not keep the water supply shut off when not in use. This will cause the tub to fill up and spill over. The following link explains how to check for this as well:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
Read through the information provided and let me know if you are having problems determining the cause of your problem. Please post back with your MODEL NUMBER so that I may be able to accurately determine how your washer is configured. I hope you find this information helpful.
Mar 01, 2010 | Kenmore 44102 Front Load Washer
Kenmore model 8566645 Washer is connected and runs but water flows out of the bottom and not into the tub.
Remove the front and side panels if you haVE TO. Look for a bad water pump most common on older units.
The fill tube to the tub from the fill valve is a second likely problem
I water filter located under the tub and in line with the water pump is also a possibility.
A bad hose is not likely but a connection to a hose could be a problem.
Jul 10, 2009 | Kenmore Washing Machines
Washer wont stop filling
There is probably a plastic tube running from the tub to a pressure switch which controls the water level cutoff on control panel. One can locate this by taking the backcover off and looking at the water level switch and following the tube to the connection on the tub. Tube must fit on level switch tightly for it to work properly.
Apr 27, 2009 | Kenmore 46462 Front Load Washer
Water over flowing in soap dispencer Whirlpool sport duet washer
A sock was in between the two tubs blocking the water going tnto the main tub. This caused the water to backup and overflow in the soap dispencer..and all over the floor I then put my hand in between the two tubs and pulled the sock out. Thanks to the expert group for giving me this solution.
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Washer overflows
water valve maybe bad.but take screws out of face of machine and lift the face to see if your vacuum hose is pinched or pulled off from water level switch.also check to see if vacuum hose is on tub of machine.
Mar 05, 2009 | Kenmore 24032\24036 Top Load Washer
Washer over flows
Dear Cbelton
please inspect the following
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
  • please rate this solution.Thank You..
    Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore 80 series model #110.26882503 fills slowly
    Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
    Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
    Too much water getting to ice maker
    The little cup that sits in front of the hose that dispenses the water, has frozen water in it . Check that first and if it's OK, then there is a small screw that you can adjust, look at your manual.
    Nov 03, 2008 | Kenmore 53642 / 53644 Side by Side...
    Washing Machines Logo
    35 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
