Question about Admiral ATW4475XQ
Admiral Washer ATW4475TQ0 won't spin and makes humming sound and has a smell like something is burning
Washer was running and went to rinse cycle and filled with water and then stopped and won't run just makes a humming noise and smells like something is burning
5 Suggested Answers
Yozzer6821
  • 116 Answers
SOURCE: Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Posted on Sep 11, 2008
  • 108 Answers
SOURCE: WON'T SPIN DRY
You need to check if there is power to the motor. If so the motor is defective.If not, the timer may be the problem. There should be a wiring diagram on the back of the unit. Using a voltmeter, trace the power.
Ray
Posted on Dec 17, 2008
caroldon
  • 17130 Answers
SOURCE: filled up with water on rinse cycle but wont work
Possible fault in the control panel , could be that the sequential switching to the next cycle is not outputted due to a failed device - a relay.
Remove the panel and check for dry soldering or parts that are burnt in your observation. Also check the voltage in the spin cycle and if this is absent the panel is a suspect as the processor does not advance from the memory set.
Posted on Jul 04, 2012
fleetsbarber
  • 6 Answers
SOURCE: Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Posted on Oct 02, 2012
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Where is the cold water valve on amana washer
the cold water valve is at the end of the hose at the back of the machine
if the cold water pipes run outside to the garage , it is a fair bet that the water in the pipes has frozen
easy to check --take the cold water hose of the tap and see if it runs
if it runs replace the solenoid for the cold water valve
May 10, 2017 | Amana Washing Machines
Estate Washer Model TAWX700JQ0 Washer fills when started... Does not Wash, Spin, Rinse, or Drain. during the wash cycle the water fill solenoid sounds like it is energized but no water is entering the...
You say washer fills and then you say no water is entering the washer?? Burning smell is most likely motor overheating due to maybe something stuck in drain Pump.
Nov 14, 2017 | Estate TAWX700JQ Top Load Washer
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
My admiral washer ATW4475TQ0 makes a thumping noise at end of spin cycle and when lid is opened during spin. What could be wrong?
there are stabilizers on the drum if they have fell off or broken away the drum will swing wildly around on spin this will cause the drum to "hit" the inside of the washer,,,check the drum stabilizers are in good order
Aug 08, 2010 | Maytag Washing Machines
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Admiral ATW4475XQ Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
