Question about Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ
Admiral Washer ATW4475TQ0 stopped on rinse cycle and now it just hums and won't run
SOURCE: Machine won't stop filling
Sounds like your solinoid valve needs replacing. It cuts the water off when it has reached the right level.
Posted on Apr 14, 2007
Yozzer6821
  • 116 Answers
SOURCE: Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Posted on Sep 11, 2008
SearsTechToo
  • 261 Answers
SOURCE: Top load washer Admiral # AAV7000AWW
I would replace the belt part # 21352320 which cost about 20 bucks. Tilt the machine back when off and empty and look for a glazed belt with maybe some cracking and wear.
Posted on Oct 04, 2008
donnastr
  • 10 Answers
SOURCE: Admiral Washer not spinning
broken or slipping drive belt, ( motor) to spin pulley , losse pulley, defitive drive clutch, spin brake fails to release, or transmission is frozzen
Posted on Oct 08, 2008
  • 67 Answers
SOURCE: Admiral Washer........Spin cycle not working.
BAD LID SWITCH
Posted on May 18, 2009
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Filled up with water on rinse cycle but wont work
Possible fault in the control panel , could be that the sequential switching to the next cycle is not outputted due to a failed device - a relay.
Remove the panel and check for dry soldering or parts that are burnt in your observation. Also check the voltage in the spin cycle and if this is absent the panel is a suspect as the processor does not advance from the memory set.
Jul 03, 2012 | Admiral Washing Machines
My admiral washer ATW4475TQ0 makes a thumping noise at end of spin cycle and when lid is opened during spin. What could be wrong?
there are stabilizers on the drum if they have fell off or broken away the drum will swing wildly around on spin this will cause the drum to "hit" the inside of the washer,,,check the drum stabilizers are in good order
Aug 08, 2010 | Maytag Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Admiral Leaking
Jul 12, 2008 | Admiral AW22 Top Load Washer
Jul 07, 2008 | Admiral AW22 Top Load Washer
Admiral washer AAV8000AWW
the timer motor is either bad or there is no power going to the timer motor.that is why the timer is not running.
Feb 22, 2008 | Admiral AAV7000A
Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ Logo
56 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
