Question about Estes Dart Quad Copter RTF ESTE4605
Flashing lights on dart - Estes Dart Quad Copter RTF ESTE4605
What are similar games to Lawn Darts?
Similar games to Lawn Darts could be Crown Darts, which is a game in which one uses the same equipment as in Lawn Darts but where the target is a target dart instead of a plastic ring, or Kubb, a similar throwing game that involves wooden batons instead of darts.
Sep 22, 2013 | Sport & Outdoor - Others
Do I need to care about the dart's weight?
Soft tip darts range vary from 14 to 20 grams, andsteel tip darts vary from 18 to 26 grams, but don't' worry if your dart is outof this scales it should affect the quality of your dart at all.
Aug 01, 2012 | Sport & Outdoor - Others
What's the retractable point on a dart?
When a dart strikes the wire on a bristle board, thepoint of the dart retracts into the dart body. This allows the point to slipoff the wire while the forward motion of the dart body and hammering the pointinto the target. You can find many steel tip darts that offers a retractablepoint.
How to choose the right dart tip?
Steel tip darts are mostly used with bristledartboards. Steel tip darts have a very sharp steel point to stick in the fiberof a bristle board. Soft tip darts are mostly used with electronic dart boards.Soft tip darts have a flexible, plastic tip on the end to easily lodge into theholes on electronic dartboards. I prefer the soft tip because it's usuallylighter than steel tip darts.
What's the highest score you can get on darts?
The highest score possible with three darts is180, commonly known as a "ton 80" occurs when all three darts land inthe triple 20. There are many different types of dart game and the maximumscore changes from each one.
What are the general rules of playing darts?
The rules of darts are quite basic. I will outline them for you here:
  • - Each player turn consists of throwing 3 darts
  • - Both feet must remain behind the throw line until the dart has been thrown
  • - Darts that bounce off the board (by hitting the wires) do not score and cannot be re-thrown
  • - If a dart falls out of the board during your turn, the darts are disqualified and the points do not count
  • - Darts dropped accidentally can be picked up and still played
  • - After 3 throws, the player must remove their darts from the board
Jul 26, 2012 | Sport & Outdoor - Others
What is the right way to hold a dart?
There is no "right" way to hold a dart. The art of holding a dart is very personal and varies greatly amongst all dart players. Some players hold their dart like a pen with you first finger over the barrel and the second finger under it, while others use four fingers to hold the dart. One thing that is constant is that your thumb is the power force - your fingers help to promote precision.
What is piggybacking?
Piggybacking is happening when a dart follows an earlier dart and sticks into the shaft of the earlier dart. This may be causing the darts parts to break but it means that the player is improving as he managed to have his or his team's darts follow each other and land on the same target point.
Jul 09, 2012 | Sport & Outdoor - Others
Do all players have to play with the same dart weight?
Yes you can. Each player can choose his own darts. There are many types of darts and they differ in material, shape, weight, length and more. For more info about dart rules, you can try this link: http://www.darts.org.nz/darts-rules.htm
Estes Dart Quad Copter RTF ESTE4605 Logo
358 people viewed this question
Top Estes Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Estes Toy Expert? Answer questions, earn points and help others
