Question about Jandy Pool & Spa
PDA locked out
Pump not working under pool mode
    Top Expert:
  • Jandy Master
  • 5,075 Answers
Go into system set up make sure pump isn't locked out if so change it
Posted on Jan 30, 2016
Pump turns on per schedule - goes into Spa mode and locks in spa mode.
switch both actuators to other position see if that works if not need more info
Mar 09, 2016 | Pool & Spa
New pool pump motor governor keeps tripping under load
READ ALL .. sounds like your power is 120 v, check with meter on L1-L2 . if it says 230-240v the switch might be lose or there is just way too much back pressure OR the impeller is too big for the motor OR the shaft seal is installed wrong, when spinning the impeller by hand "snap of the wrist " it should almost make a full turn.
remember to vote or reply... Jay the pool pump repair guy in longwood Fl
Apr 17, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
Summer escapes pool pump won't turn on
Take a look for new pump on amazon, click here: Amazon com pool pump. I hope this was helpful. Cheers
May 14, 2012 | Pool & Spa
Pool pump wont prime when in pool mode, but will run in hot tub mode. Hot tub is 3 ft higher than the pool... is this a bad impeller? I think it may have run for a few hours without a prime , as I...
I assume that it pumps from/to the hot tub. If so, the pump is fine. Look for any air leaks in the piping/hoses from the connection in the pool to the inlet of the pump.
Gary
Aug 30, 2011 | Hayward 1.5 Hp Northstar High Performance...
What settings are best on the two (2), 3 way psv diverter valves on a hayward pool de filter system
First figure out how the valves work. In the filter mode the valves should be set so the pressure from the pump flows into the input of the filter and the output of the filter flows into the return line to the pool. In the backwash mode the pressure from the pump flows into the output of the filter and the input of the pump flows to the drain line. These are the two main modes.
Aug 16, 2009 | Pool & Spa
Pump works in spa mode, but doesn't work in pool mode. Why?
We need more info. Which control system is it? Suntouch, easytouch, intellitouch.......? It sounds like a programming problem in the controller.
May 25, 2009 | Pentair 3hp Whisperflo Pool Pump In -...
Pool motor keeps turning off. Runs fine in "Service" mode but as soon as I switch the controller to "Auto" mode, it starts for a second, then quickly turns off. It keeps trying over and over but then it...
Well, since this is brand new, it is still under the normal
warranty period. There must be something wrong with the controller, since it works fine in Service Mode. Just
get in touch the dealer where you buy the unit.
May 02, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Pool & Spa Logo
76 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
