Question about Saeco Vienna Espresso Machine
Steam light comes on.. starts to work but then stops and flashing red light comes on. What am I doing wrong
4 Suggested Answers
espressodoc
  • 29 Answers
SOURCE: red warning light does not go off
The red warning light is multifunctional. Be sure all your components are in tightly especially the central brew unit.
Posted on Jul 29, 2007
EsWorld
  • 1618 Answers
SOURCE: Steam stops after few seconds and water and temp lights blink
Check the 2 limit sensors on the boiler.
Posted on Jun 20, 2009
  • 115 Answers
SOURCE: I own a saeco Vienna
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Posted on Sep 24, 2011
Red light flashing fast
The main reason for the Fast flashing red is with the water flow meter.
located at the back part of the machine below the power connector - its functionality can be checked in diagnostic mode .
see attached pictures
its either stuck due to in proper descaling or have corrosion in the connector contact of the flow meter.
You can fined the full service manual at Partsguru
http://www.partsguru.com/user/SERVICE%20MANUAL%20TALEA%20ODEA%20REV.03.pdf
Jul 24, 2013 | Saeco Odea Giro Plus Coffee Maker
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
After a short time of using my steam cleaner the red light comes and steam stops.
red light of course means stop, so do. second its a vacuum so my next assumption is its full either it needs to be emptied or cleaned so it can resume its job. I hope this helps.
Jul 13, 2011 | Domena NVT200 Steam Vacuum
My incanto classic worked wel for years. But hthere is a problem now. After refilling the water reservoir the left red light is flashing. I start refiiling by opening the steam circuit. I hear the...
Hi Your problem is the flow meter. It has a restriction and is not sending the correct signal to the computer. Replace the flow meter and you should be good.
Feb 21, 2010 | Saeco Incanto Classic Espresso Machine
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Water tank light is flashing with main heating light
HI
I don't think your machine is finished descaling. Follow these steps.
With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz’s. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don’t turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and your ready to go.
Apr 13, 2009 | Solis Palazzo Espresso Machine
Swan steam station S12010
i have a steam station , the stand-by light keeps flashing on and off, how do i reset it, there is no steam comin thriugh at all, please help.......thank you xx
Oct 14, 2008 | Irons
Coffee is not coming out
take out the brewing unit and clean it.
Make sure all parts is on place, try to open the steam knob and make a full cup of water (tea).
Let me know if you need more help
Best regards
/Mirran
Sep 24, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Espresso Machine Logo
29 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
