Question about Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive
Harddisk not showing on pc
My pc will not recognise the harddisk anymore.I wont show in my computer butI can find it in disk management but it`s not possible to change the letter or activate it.I can format but this is my backup harddisk and all my pictures are in there.I`ve tried it on my husbands pc and then it`s recognised.seems like I need to download new drivers bt where?Since I`m not a nothamerican user I can`t download it from buffalos homepage.So what can I do?
  • 106 Answers
Is the disk backup or in the pc internal hard-disk if external no need software download just get another pc or use recovery software to get your data from it and then format and re backup your data
Posted on Jun 27, 2017
  • 135 Answers
SOURCE: hi i got a buffalo tb external hardrive and the pc
It is probable that since the transfer did not complete, the data on the external drive will be corrupt.
Uninstall the external drive then reinstall and format the ext drive.
You should then be able to begin the data transfer process again.
It just sounds like bad luck that your pc froze mid transfer.
When you try again, do not use the pc for any other uses until the transfer has completed.
Regards and let me know if this works for you.
Posted on Feb 24, 2009
  • 64 Answers
SOURCE: time for physical format ???
Did you fit the drive into the Buffalo drive case? If so, take it out and put it in your computer tower/case and format it from there. Then put it back into your Buffalo case.
Go to the Buffalo sight and see if your Drivestation needs a firmware update - there may have been bugs in the one you purchased.
Posted on May 19, 2009
  • 6831 Answers
SOURCE: Buffalo external hard drive not recognised on PC
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Posted on Sep 29, 2010
  • 10406 Answers
SOURCE: my usb external Buffalo ministation
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
  • 10406 Answers
SOURCE: Everything worked fine until yesterday
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: for a "no data - no charge guarantee".
Posted on Nov 11, 2010
Testimonial: "THanks - I'll give it a go!"
My lacie harddisk doesn't show up in windows XP. Power is ok. Light is on and he makes normal operating noise like always. I have another one for which I use the same USB-chord and that one is working...
1. right click the my computer
2. go to properties
3. click hardware tab
4. and click Device Manager
5. show the Device Manager and click disk drives
6. your hard disk is show or not.
7. it's show then go my computer properties
8. select manage and show computer management window
9. then click disk management
10. your hard disk partitionis show right click the partition add driver letter (ex: h:, i: ..)
11. after open the my computer the partition is show
Sep 15, 2010 | LaCie F.A. Porsche (301177) Hard Drive
Storejet problem
Good day!
1. Go to my computer and right click then click manage, go to disk management and see if your external harddisk is showed.If showed,then you can see the options there to manipulate your harddisk, either you format it or repartition.
2. You can use also a disk manager software to fully control the function.
Jul 06, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
PC not recognising Iomega Prestige 320gb usb portable hard drive. I've connected it all up, disconnected, reconnected, rebooted the computer, but the drive is just not recognised and does not show up in...
Does the drive show in Device Manager? Right click on 'My Computer' and select properties, the open device manager.. Navigate down to Disk Drives or Hard Drives, click on the plus sign and see if your drive is listed. If it is, then right click on the drive name and open properties for the drive. Click on the 'Volumes' tab and hit the 'Populate Button'. It may be the disk just needs initialising, then reformatting before you can use it. If it does need initializing, a wizard should appear to guide you through the process!
If this doesn't solve your problem, try using a different USB cable and/or USB ports on your computer, and ensure to unplug all other USB devices other than keyboard & mouse.
Mar 06, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
I put my old hard drive in as a slave, vista recognises it in management and device manager but doesnt recognise it in my computer?
it might need to be formatted, right click on the computer and click on manage, click on disk management and format the disk.
Mar 03, 2010 | Acer Aspire m5640 PC Desktop
Harddrive does not start recognises
Try Control Panel, Administrative Tools, Computer Management, Storage, Disk Management.
Check there to see if the drive is listed, "online" and has a "Healthy" Partition.
Nov 17, 2009 | Western Digital Passport WDXML800UE...
I have a problem in my harddisk it show the icon in the taskbar but it is not showing in my computer please help me!
If it is a new harddisk you will need to format it.
go to the start menu and right click on "my computer" and select manage. Then find "disk mangagement" in the left panel. find the new drive and right click on it and choose format it.
After formating, which may take a while, restart the PC and you should have it in veiw.
Aug 09, 2009 | Transcend 2.5" Solid State Disk - Solid...
Unable to delete data or format or partitioning samsung HDD
Have you tried booting from a Windows XP CD? If you have one available you can boot from it, delete the partition and format it. Works all the time for me.
Jul 30, 2009 | HP Computers & Internet
Jun 06, 2009 | BenQ Computers & Internet
Disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
My dvd rw is not detected
Sounds like you need your manufacturer's SATA drivers.
This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
Aug 20, 2008 | Microsoft Windows XP Professional With...
Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive Logo
44 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
