Question about Ultra (ULT30982) Cooling Fan
Remove ultra cooling fan sd-9025hs - Ultra (ULT30982) Cooling Fan
5 Suggested Answers
edgreason
  • 120 Answers
SOURCE: It's broken and I need to replace. What is
http://guide.opendns.com/track/click.php?q=sd-9025hs&curl=http%3A%2F%2Fwww.jsneaker.com%2Fpentium-cpu-fan.html&search_grp=MAINRESULTS&search_pos=0
Posted on Apr 09, 2010
SOURCE: SD-9025HS fan blade broken
http://www.geeks.com/details.asp?invtid=K8A9-8SB3-BULK&cat=FAN
The replacement by this part will be easier than trying to find a new fan for the ULTRA.
Posted on Feb 08, 2011
SOURCE: problem with my SD 9025HS
Buy a new fan. Tee one you have is dead and the system is shutting off because your processor is overheating.
Posted on Feb 27, 2011
bronk50
  • 27725 Answers
SOURCE: I've got a SD-9025HS cooling
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Posted on Apr 20, 2011
I have a primos truth cam 35 ultra.it displays loc after I removed the SD card help
If it is woroing aft3rcyou remove the SD card, then check the SD card in another device to see if it works there. They sometimes fail.
Jul 04, 2015 | Primos Home Security
Cooling fans A2121
you will need to remove the battery remove the top casing where keyboard seats once thats remove you will be able to see the fans and can be remove pretty easy.
Feb 05, 2013 | Apple MacBook Pro 17" Intel Core 2...
I've got a SD-9025HS cooling fan that has stopped working. Where can I get a replacement?
Add Email adress
Add Bank Acc
Add Credit Card
hope this helps
Apr 20, 2011 | Ultra (ULT30982) Cooling Fan
Problem with my SD 9025HS the fan does not turn and the system crashes after a few hrs of running what is the solutuion to this problem??
Feb 20, 2011 | Ultra (ULT30982) Cooling Fan
Nov 20, 2010 | Ultra (ULT30982) Cooling Fan
It's broken and I need to replace. What is compatable with model SD-9025HS?
Apr 09, 2010 | Ultra (ULT30982) Cooling Fan
The fan on my PNYvertoGeForce5200 ultra video card does not work?
Yes you can get a new fan if you can or you might look for any system that does not work anymore and remove the fan if it fits yours.
Best wishes
Nov 11, 2009 | PNY Verto GeForce FX 5200 Ultra (128 MB)...
My Flip is not charging
Remove the battery cover and use a fan to cool the unit down during charging on the USB.
Oct 26, 2009 | Pure Digital Flip Video Ultra Camcorder
Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Cheers
Mar 26, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Ultra (ULT30982) Cooling Fan Logo
152 people viewed this question
Top Ultra Computers & Internet Experts
Gareth Cockram
Gareth Cockram
CheckitRight
CheckitRight
Alan Hohenbrink
Alan Hohenbrink
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
