Question about Epson Stylus Photo R200 InkJet Printer
Faint blue horizontal lines
Faint blue horizontal line show up when I print a document.  I have ran all the diagnostic tests such as cleaning of heads, alignment.  The ink level is about 50% full.  Any suggestions?
  • 2 more comments
  • sallylou Nov 05, 2007
    I have re installed my drivers for my printer. And I have tryed to clean the head mechanism by applying a few drops of windex. (this was suggested by another support tech) I also changed out the two cyan ink cartridges. I still have faint blue horizontal lines, Has anyone else had this problem with their epson stylus r2000 printer?
  • Anonymous Mar 31, 2008
    Photo was coming out real light, the black ink was low, so i replaced the black ink with a new one. Now the printer will not print any of the colors. Cleaned the head several times, still will not print any of the colors the photo comes out blank..
  • Visor4 Jan 10, 2009
    My problem is similar, but it happens with my black cartridges, and occurs mainly when printing on CDs. With plain paper, I see lines when printing a test page in "Text" quality mode, but when I bump it up to "Photo" quality, the bands go away. For CDs, the Epson Print CD program automatically sets the quality to "Best Photo" but the lines are still there when printing to CDs.
    Tried uninstalling and reinstalling the printer driver as the guy says below (on a side note, the uninstaller claims the driver version is 6.06E, even though the Epson website only provides a driver for version 5.5A. When I installed 5.5A, the installer still said it was 6.06E). At any rate, there was no change.
    I was using cartridges that were refilled by Island Inkjet. I swapped out the black cartridge with a geniune cartridge; same problem.
    Followed some of the print head / nozzle cleaning instructions provided here:
    Still no change.
    I saw a posting somewhere saying that it could be a problem with the logic board. Considering the age of the printer, it's not worth getting this looked at. I guess I'll just use up the rest of my ink and buy a Canon later this year.
  • Charles Durang Feb 05, 2009
    Just noticed that when printing from a PDF document, I don't get the lines! This tells me it's a driver, not a mechanical problem. (I;m assuming PDF has its own driver.) Every other print job gives me the lines.
  • 749 Answers
Try re-installing the printer driver it might be caused by a virus... if not then you need somebody to clean your printers head mechanism.. the blue cartridge might have messed an ink to its circuit.
Posted on Oct 31, 2007
  • Rommel Balcita Nov 17, 2007
    Ok... can you try to install your printer to another computer, say to a friend to test if your computer is the problem or the printer itself. If it is the same problem then the printer has a problem with its data cable... If it is clean, no faint blue prints, then you have to re-install your computer.
Two faint white horizontal lines
the white ghost lines are down to the charge wire within the toner cartridge being dirty, the only real way forward is to replace the toner cartridge as access to the charge chorona wire is not possible without ruining the cartridge itself
Jan 09, 2014 | HP LaserJet 1000 Printer
The color is not printing correctly. Things are coming out mostly pink or yellow. I tried the MAINTENANCE tab. The nozzle check showed that the top section (PGBK) looked good. The second section (C)...
The printhead has either become too clogged to flush out with with the internal cleaning operation (which uses a LOT of ink), OR, the nozzles are not firing. If after several cleaning operations there is still no significant improvement, you will need to replace the print head. I see this frequently with Canon and Epson, and Brother inkjet printers. Usually, it is due to leaving the printer idle for too long, or removing a cartridge and not replacing it right away. The air gets to the residual puddle of ink in the head and dries it.
You can find the replacement print head by Google searching "MP830 print head". Prices can vary from around $70 - $90. Changing it out is fairly simple. You only need to lift a lever that holds the head in place. Make certain that it is squarely seated, and then run a few pages of a color document, or do a couple of standard cleaning operations to "prime" the head.
Make sure the hed is NEW and not used or "refurbished". Here is one source on eBay that sells it for $78.00:
Nov 27, 2011 | Canon MP830 All-In-One Printer
Hi - I have a 3-4 year old Canon Pixma IP4500. The initial problem was blurring in places on black text. Nozzle check showed that bottom half of PGBK grid was missing horizontal lines. Took out the print...
one idea is that you rouined printhead with tap water and second idea is to buy new print head or printer.
Note: If you want to replace ink head, be sure to replace purge unit and ink absorber also.
Sep 02, 2011 | Office Equipment & Supplies
Hi, my Epson 2100 is printing with faint lines at regular intervals right across the page. I've done various alignment tests and cleaning tests but can't seem to clear the lines. Any advice much...
Are your alignment tests show good results? If they are, try head cleaning 3 consecutive times without printing nozzle checks. After 3 head cleanings do the nozzle check. If problem persists try printing at BEST PHOTO or whatever is the slowest print setting for your printer. Good luck!
Jan 14, 2010 | Epson Stylus Photo 2100 InkJet Printer
When I print blue horizontal lines appear or being printed as wel
Do the cartridges ride on the printing carriage, or do they plug in somewhere else in the machine and have hoses that run the ink to the print head? If they ride on the printing carriage and the cartridge is new, there could be a short in the printer and it needs repair. Check if there's ink smeared on the print head or part of the printer. Generously clean the print heads with lots of paper towels and rubbing alcohol. If that doesn't work, to see if it's an issue with computer, print a test page from the printer, but don't send the print job from the computer. You need a print job generated from inside the printer itself. Not every printer can do this, but try pressing paper feed, holding down paper feed and power, or holding down cancel and power. If the blue lines disappear then but they didn't when you cleaned the heads, it's a software issue.
Sep 17, 2009 | Epson Stylus Pro 4800 Color Photo Printer...
Prints Faint green horizontal lines
Go to control panel and printers and faxes and right click on printer icon then hit printing preferences, go to maintenance and do head cleaning cyles and print nozzle check. if it comes out fine trash and reinstall driver
download driver from site after selecting the printer mdel on the lists
Apr 12, 2008 | Office Equipment & Supplies
HP 7110 still won't print in color
Your post " prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Apr 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
HP Color Laser Jet 3550 Smearing Colors
Do you use original genuine cartridges or refilled ones. It sounds like you have had a leak and need to completely clean out your printer heads, rollers and perhaps do a deep claean as well. You can buy faulty cartridges and toners that have one leak, then the ink continually leaves traces as it prints. When you say callibrated, do you mean you ran print tests and setting tests. Running a print test can often help to diagnose ink issues an d narrow the results down a bit. After a thorough clean, you could try uninstalling and reinstalling unit.
Aug 11, 2007 | HP Color LaserJet 3500 Printer
Epson Stylus Photo R200 InkJet Printer Logo
516 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
