Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool model no. eb9shkxvqo3 bottom freezer
Doors open all the way need to adjust
  • 1462 Answers
SOURCE: freezer door needs to be raised
just put some washers (plastic washers are best) on the hinge pin to raise the door
Posted on Nov 16, 2008
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
cj2176
  • 520 Answers
SOURCE: Refrigerator top freezer door slightly rubs to
I think I can help. Usuly the doors have been swapped around in this case. look closely at the freezer door on hinge side. there should be a small metal piece that covers the hinge to prevent anything from jamming hinge. this shield also serves as a spacer. this is what sets the door at the correct height. if the piece is missing you can have your local appliance dealer order one for you. it only takes a few minutes ts to install. you will need to remove the freezer door to do this. Hope this helps and good luck.
Posted on May 07, 2009
  • 22 Answers
SOURCE: light clicking sound from outside whirlpool french
Check the fan blade on the fan in the freezer. It could be an object or ice, frost, anything. If this is an Amana Whirlpool, definitely check to see if the fan blade is no longer tight on the motor shaft and has moved forward and hitting the guard in front of it. ( yes, amana whirlpool )
Posted on May 12, 2009
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
Bottom freezer door stuck closed due to food blocking. How can I get door open? Whirlpool Gold Model GX5FHDXVQ01
Hi Pat, that's a tough situation. Are you able to get the door open at all to slip something long through like a piece of wood to maneuver stuff around in the freezer?
If you can't, maybe turn down your freezer to start a defrost, or do a complete defrost.
Sep 04, 2016 | Whirlpool Refrigerators
Whirlpool fridge door "drops" into place when opening.
are both door leveled? if not the door cam worn out and need replacement
Nov 23, 2017 | Whirlpool GSS30C6EYW 30 cu. ft....
The bottom freezer door on my Kenmore refrigerator 795.7900 pops open each time I close the top door. I have tried adjusting the leveling screws and it hasn't helped. Any suggestions?
Glen you keep adjusting but before that try to find this unusual problem. On its own, doesthe freezer door close witha thud? If not it needs adjustment otherwise other problems could surface.
Mar 03, 2014 | Kenmore 72912 / 72914 / 72919 Bottom...
WHIRL POOL STAINLESS STEEL FRENCH DOOR- BOTTOM FREEZER MODEL NUMBER GI5FSAXVY
You should be able to buy replacement stripping at any local hardware and furniture store.
Sep 16, 2013 | Whirlpool GI5FSAXVY Stainless Steel ...
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Whirlpool Refrigerators
My model is ARB 1914 CC nine years old.
your "damper vent door" located between the refrigerator and freezer compartments is frozen open or the cold adjustment contron in the refrige is bad and not powering the door as you change the temp set for the refrige and leaving it open,if the door is frozen from ice/frost just de-ice it with a hair dryer and then set the temp adjust and see if it opens and closes with any adjustment
Apr 03, 2010 | Amana ABB1927DE Bottom Freezer...
I have a Whirlpool Gold refrigerator w/french doors, model GI5FSAXVY. The door on the right is set higher than the other, not allowing me to open my cabinets above. How do I adjust the height of the one...
you might be able to get a little room
look at the bottom hinge of the door
the one you want to lower
you should see a few spacers between
the bootm of the door and the top of the hinge
as well as being able to lower the hinge pin by screwing it down
Oct 11, 2009 | Whirlpool GI5FSAXVY Stainless Steel ...
Whirlpool bottom freezer 5 years old everything freezes in the fridge
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer door needs to be raised
Nov 16, 2008 | Whirlpool ET0WSRXML Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
35 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
