Question about Weber Gas Go-Anywhere Grill
Does not have high flame only low flame - Weber Gas Go-Anywhere Grill
Which is the lower setting on Thurcroft calor gas stove
I am not familiar with this stove but I think you could turn on the stove and look at the flame while you turn the knob to see which way is high or low.
Jan 07, 2015 | Kitchen Ranges
It only gives low flame upon starting and cannot
close your air vent on the burners it will increase the height of the flame
Mar 27, 2010 | Grilling
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
My Viking gas oven is slow to heat?
very likely the thermstat is defective, most likely the oven temperature proble
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Jun 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Weber Gas Go-Anywhere Grill Logo
70 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
