Computers & Internet Logo
M
Michael McDonald Posted on Feb 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turn power on stays on few mintues then shuts down turn power off and back on does same thing screen looks a little dim
bsheep
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 189 Answers
  • Posted on Sep 10, 2014
bsheep
Expert
Level 2:
New Friend:
Cheetah:
Answers
189
Questions
Helped
31741
Points
358
What kind of computer do you have what kind of os or operating system windows xp,200, vista just to name a few
5 Related Answers
Anonymous
  • 159 Answers
  • Posted on Jul 12, 2008
SOURCE: Gateway Monitor FPD1760
Power light coming on when you plug it in but no lighting of the screen is usually caused by the power inverter board having gone bad. Common on the 17s due to their age is a bad bulb or more.
I repair these 90% of the time
[email protected]
Anonymous
  • 133 Answers
  • Posted on Aug 17, 2008
SOURCE: Blank screen, but has power
It is most likely a backlight that has burnt out or something else of the sort. You will want to call HP Support and explain to them of your troubles.
Anonymous
  • 8 Answers
  • Posted on Apr 16, 2009
SOURCE: Dell lcd monitor, turns on but only stays on for about 30sec
The problem is your backlight lamp is bad. Your description is of very classic symptoms for the backlight. You can either replace the LCD assembly or monitor or try replacing the backlight bulb itself. You'd have to call around to some repair shops to see what they'd charge to see if it is worth it to you to fix it or replace it. Here is a link to a site online that shows the bulbs and how to replace them if you want.
http://www.ccfldirect.com/?gclid=CPPCiNau9JkCFQkzawodGFudQg
Anonymous
  • Posted on May 15, 2009
SOURCE: shuts down after a few seconds
monitor come on for two seconds and them go blank
Anonymous
  • 208 Answers
  • Posted on Sep 02, 2009
SOURCE: Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
I have a Blank screen on Vizio TV?
Hi Ed...You need to find if the backlights are staying lit or if they're shutting down completely. I have a feeling you have bad backlights but it could be other things as well. Take the back off and you should be able to see if they shut down, on this model it's normal for them to dim if no image on the screen but they shouldn't go out. I've had issues also with the backlight control circuitry on the power supply, this is an edge lit set and the lamps on this type of set are more troublesome than sets with strip
1helpful
T43 screen dims and laptop will not shut down
The screen will dim on battery power to save energy. The power settings, found when you right click the power icon in taskbar notification area and go to power options, can be changed to your personal preferences. The shut down issue may be what is running, I can't say what is running, but look at the Start up process in MSCONFIG and shut down what is not necessary at Start UP. Look at tutorials on Faster Start up and Shut down. There may be many items you can shut down/disable to speed up these events. QUESTION: Is this a upgrade to WIN 7 Ultimate, If so your computer me be a bit short on specs, in other words you have reached the computers hardware limits. How much RAM, CPU speed...etc.
My monitor went dim and goes black after a few seconds. I can just turn off the monitor for a few seconds and then it comes back for a few more mintues but still is dim and goes black again. Also while...
I don't know what OS you have but there is a power management setting you might want to check. Most likely the monitor is set to go quickly into sleep mode at inactivity. Alternately I don't know what monitor you have but it might be a backlight Issue as well
M1991 screen stays black, little light is yellow
The fault is a back-light problem and the fault could be a faulty inverter board or a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link :-
www.lcdparts.net
2helpful
2answers
Running just fine then just stop but starts back up after a few mintues
With the little bit of information I have two ideas.
1) fuel filter
2) fuel pump
Computer shuts down after 15 mintues or so. Replaced power supply, so thats not the problem. After 10 mintues computer might come back on. Sometimes the fans will come on and nothing else. It very...
It would be useful to have more complete info about your system. Model, OS, RAM, etc. However, there are a few generic possible problems.
The power supply receptacle on the motherboard may be out of spec ... it does not secure the power connector properly.
You may have a software or driver conflict. Use some thing like Belarc (free at belarc.com) to get a list of software and driver versions for your computer. Check with each manufacturer's website to ensure that your OS version and level is listed in their "system requirements". If not either remove the software or driver or update it.
3helpful
2answers
Screen stays dark
How long have you had your computer? Mine has been doing this. The battery has died out over time, and now I think the adapter is too. It's kind of kinked near where it plugs into the computer (probably from the weight of the chord constantly being pulled down). It just gets a bad connection, a little less power, and goes dim like that. If I readjust the connection and turn off/turn back on the computer, it usually comes on bright again. But I ordered a new battery
Blank screen
the power is supposed to stay on when that little plastic button is pressed(screen switch)the screen switch activates hibernate and power saving;if you press the power button a screen will open informing you what programs are currently working.by shutting down you have caused an illegal command.
hopefully if you restart in safemode then shut down correctly and restart every thing should be ok.
Top KDS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Eric
ADMIN Eric
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
