Question about Canon MP20DH III Scientific Calculator
Manuel decription for feeding paper for printed information
Will not feed in paper
TONY, UNPLUG PRINTER FOR 3 MINUTES REPLUG TRY PRINTING SOMETHING ALSO YOU MUST CLEAR ALL PRINTING JOBS THAT ARE IN THE MACHINE NOW,, CALL CUSTOMER SUPPORT FROM NUMBER IN YOUR MANUEL ,,TRY ALL ABOVE THANKS
Jan 24, 2016 | Office Equipment & Supplies
The paper feeder does not work. It hums and shows error.
DEBBIE LOOK IN THE OPERATORS MANUEL OR CALL CASIO CUSTOMER SUPPORT
Jan 21, 2016 | Casio Office Equipment & Supplies
Does not print on the receipt. The paper feeds out as if it were printing, but it comes out blank.
try replacing the ribbon for the printer that prints the reciepts. they do need to be changed after some period of time. Check your owners manuel for instructions.
Mar 20, 2015 | Casio PCR-T2000 Cash Register
Brother mfc-7420, how do I get off manuel paper feed
Thank you for following me up, I managed to discover that the document I was trying to print was set up for manuel paper feed, other documents subsequently went back to normal after printing the offending document. However is there a setting on the actual printer to control this.
Regards John
Oct 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Apr 17, 2009 | Epson Stylus C86 InkJet Printer
My Lexmark X1185 will scan but will not feed to print
You probably need to adjust the roller or do an alignment. Your owners manuel should have the info on how to do this.you can probably clean the roller . If it shiny it will not pull up the paper. Check it out.
Oct 29, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Printing business cards
Feed sheets through front manuel feed slot.
base tray is mainly for up to 90grm paper,anything heavier
can feed for a time but tends to fault.also try and clean the
paper pick up rollers regularly.
mongrelken.
May 20, 2008 | Brother HL-2040 Laser Printer
Zebra LP 2844
The printer is in line mode. Do the following to take it out of line mode:
Turn printer power off.
Hold the feed button while turning printer power on.
When the light starts flashing, release the feed button.
When the light starts flashing again, press and hold the feed button.
When the light turns steady amber, release the feed button.
When the light turns steady green, the mode is changed.
Verify the mode by printing and inspecting a status report.
This requires good timing and may take several tries. You'll know it worked if no labels are reeled out after you're done.
Feb 28, 2008 | Zebra LP 2844 Thermal Printer
Hp color laser jet 4700n
Go to the paper menu set tray 1, Letter size and "any" for paper type.
Set tray 2 Letter and paper type "Plain"
Oct 10, 2007 | HP LaserJet color laser printer
Canon MP20DH III Scientific Calculator Logo
26 people viewed this question
old marine
old marine
