Question about Craftsman Crafts & Hobbies
Parts for 9-80444
I need glue sticks
    Habit-Forming:
    New Friend:
  • 25 Answers
Try returning the glue gun at the local sears store for an exchange for one which uses round glue sticks.
Posted on Jan 18, 2016
Need the instruction manual for a Stanley GR100 glue gun
I do not believe there is a manual. there are instructions on the package. Insert the glue stick and turn on the gun. When the glue melts and the trigger moves glue will come out the front tip. This model has 2 temperatures so if it delivers too fast or runny you can lower the temperature. You pull the trigger to push the glue stick into the heating element to melt the glue. It is pretty straight forward. As the glue stick is consumed you stick in another glue stick. I suggest testing on something before using on your project. Do be careful of the hot end. It will definitely burn you if you touch it and the glue coming out is nearly as hot as the metal.
Jan 17, 2014 | Stanley Gr100 Glue-pro Dualmelt Glue Gun
How to use glue gun
PLug it in and if there is a on/off swith turn it on. The gun's heating element will get hot. When it is hot enough to melt the glue stick you have put inside through the hole (that is glue stick sized and on your end) then the trigger will push the glue stcik into the hot metal melting and coming out the end so you can deliver it where you want to glue something. Beware of the heat. You absolutely can burn yourself touching the hot parts of the glue gun. Think how you would not touch the hot part of a steam iron... same problem.) That's pretty much it. Pull the trigger to push the glue stick though and add more sticks as you need them. And beware of the very hot nature of hte tool.
Dec 27, 2013 | Stanley Crafts & Hobbies
I need to glue twopieces of cardboard in a v shape to use for pleating material which then has to go into a steamer so the cardboard must stay together
You can use many different types of hot glue guns and sticks to create a "Fiber Tear" meaning the cardboard will rip before the glue bond fails. Gluegun.com has a great selection of craft & industrial guns as well as glue sticks. Try the Tough Guy glue sticks, strongest product on the market bar none - http://www.gluegun.com/products/infinity-melt-tough-guy-glue-sticks
Sep 07, 2013 | Crafts & Hobbies
My glue gun doesn't heat up the glue stick.
Is the light on? The problem may be electrical, you can try plugging it into a different outlet. Try one that you are sure is working (ie unplug something that is already working and try the glue gun there). If it is getting power, there must be a problem with the interior heating coil, in which case you will have to unscrew the casing and replace some parts
Feb 15, 2013 | Crafts & Hobbies
Hi - just bought a Ad Tech Hybrid Cordless glue gun and Ad Tech glue sticks but the sticks are too large to fit - is there a way to resize the sticks?
Ad tech makes a few different size guns. you need to make sure that you are using MINI GLUE STICKS. they should be 0.28 inch in diameter. there is no good way to resize the larger sticks, just buy the mini ones instead
Dec 31, 2012 | Ad Tech Multi-Temp Hybrid Cordless Glue...
Velcro pad that the sandpaper is fixed to has come off the plate. What's the best glue to use to re-stick the pad with?
You may try a two part epoxy, or gorilla glue. Let dry for a day or two. Sometimes 3m spray adhesive also works. Let tack before sticking together though.
Oct 19, 2012 | Dewalt DW 411 HAND PALM SANDER
Arrow TR 550 heats up fine but glue stick won't feed by the trigger. If I push the stick with my hand glue does come out, but the trigger seems to "slip" on the glue stick. Any ideas?
The trigger probably really is slipping on the glue stick. If you've changed the type or size of glue recently, try changing back to what you were using, or just something else. Maybe the glue stick is too small, or too slippery for the gun. If not that, then it's a mechanical problem. There are some screws on the side of the gun. With it unplugged and cool, take them out and open the case. It might be stuck together with some internal connections as well as the screws, but jamming a flathead screwdriver in them can usually wedge them apart. With the gun open, move the trigger and look for the parts that move with it in the area where the glue stick goes. If you can find something to attach to these parts to make them just a tiny bit longer, do that. The parts that grip the glue have probably worn down or just don't fit, and the fact that you can tell the trigger is slipping means that it's probably very close to grabbing, but not quite close enough. Any little extension to the grabbing parts should do, but be careful not to block the path of the glue.
Feb 28, 2011 | Heavy Duty Arrow Pro Glue Gun Tr550
Glue doesn't advance
with some glue guns the sitting with a stick in them wile hot the stick will get hot enough to where the gripper that advances the glue slips try to bush it through some to where you can add a new stick in or when sitting for longer periods unplug to allow to cool then re heat when needed.
hope this helps
May 10, 2010 | Crafts & Hobbies
I can' get the glue stick out of the glue gun
No need for concern. Just leave it there and then the next time you use it push a new one in as needed.
I haven't met a glue gun yet where you can take out the last remnants of glue stick.
If you prefer to remove it try this:
take a paper clip and straighten it (any thin,metal object will work) Heat the glue gun,unplug it,and then heat the end of the paper clip with a lighter/candle.
Insert it into the end that you load from,sticking it into the glue stick. Wait a short time and then pull the paper clip out. The glue stick should come out with it.
I find it easier to leave the glue stick in as I said,but it's your choice.
Oct 03, 2009 | Crafts & Hobbies
Crafts & Hobbies Logo
536 people viewed this question
Top Craftsman Crafts & Hobbies Experts
Kazim ERGUNEY
Kazim ERGUNEY
NOEL
NOEL
Are you a Craftsman Craft and Hobby Expert? Answer questions, earn points and help others
