Question about Echo Garden
Echo chain saw purge pump not purging
No fuel getting to purge pump
  • 3 Answers
SOURCE: Purge pump removal
By studying an exploded parts diagram found online, I determined that it snapped out the top before the bracket slid out the front.
Posted on Jan 30, 2009
  • 52 Answers
SOURCE: Weedeater, 18cc, replaced fuel line & purge
You may have accidently hooked the lines to the purge button wrong. The purge button (primer button) should have a short stem and a long stem. The short stem is the suction side of the primer button and should be hooked up to the return on the carburetor. You actually s*uck gas through the carb and not from the tank. The carb should have two hook ups. If you hook the fuel line up to one of the lines on the carb and the button is hard to push and doesn't return to normal, hook the line up to the other one. When you push the primer button gas should be pulled through the carb. The other line on the carb goes back to the fuel tank.80a09a6.jpg
Posted on Apr 24, 2010
  • 277 Answers
SOURCE: how do I replace the purge pump on thr Echo chain
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Posted on Jun 21, 2010
#1 Taper
  • 1041 Answers
SOURCE: how to replace purge bulb
Once you are able to get to the four screws holding the primer bulb on, simply remove the screws, grab the bulb and pull off of carburetor. Take the metal sleeve off of old bulb and replace with the new one. Reverse procedure and GO CRAZY!
If I can help you any further, let me know.
JIm
Posted on Sep 16, 2010
  • 323 Answers
SOURCE: the purge bulb cracked on my echo chain saw. Is it
you mean the primer, yeah you need to replace
Posted on Nov 26, 2010
Pe200 echo edger i have replaced the carburetor, fuel lines primer ball it runs for 30 seconds to a minute then shuts off acting like its starving for gas
Have you connected the fuel lines up correctly to the carb and purge bulb? just remember the bulb pulls fuel from the carb, into the bulb and dumps back to the fuel tank, it is a purge not a primer.
Mar 05, 2018 | Echo Garden
Purge bulb not working on echo pb-500t,gas leaf blower
get a new primer bulb and diaghram and rebuild your carb or buy a new carb,same price,gas and ethanol and oil kill carbs, echo A021000781
Echo PB 230LN 05001001 05020818 Handheld Parts
May 26, 2015 | Echo Garden
Test the purge valve on a 36cc chain saw
Make sure the return line is going directly to the tank from the purge valve, the other goes to the carb. I see these two lines mixed up the most.
Sep 12, 2014 | Garden
Need fuel line diagram for Echo CS400 chainsaw
Hi
I believe this is what your looking for
Please rate me
Bud
Oct 25, 2012 | Echo CS400 18" Chain Saw
How do I replace the purge pump on thr Echo chain saw model CS 3000
Jun 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo cs3450, how to replace purge pump
The IPL (exploded parts list) for your saw can be found here:
EchoUSA
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
Page 8 is the fuel system detail. Compared to most manufacturers’ this is a novel, a good one. Use it as a guide, it doesn't look to difficult. Take extensive notes and digital photo or two may pay huge dividends. HTH
Lou
Sep 28, 2009 | Echo Garden
Purge pump removal
Jan 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Starting problem
purge valve for gastank and emmission system
Jul 26, 2008 | 2002 Toyota ECHO
Open Questions:
Garden Logo
100 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
