Question about Frigidaire FGBD2438PF Gallery 24" Built-In Dishwasher
Reset 2438 frigidaire dishwasher
Won't cone on no lights
3 Suggested Answers
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
Same thing happened - couldn't do anything - was completely "locked"...tried the breaker reset and it worked immediately. Thank you for sharing the answer!
Posted on Jan 10, 2010
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: fRIGIDAIRE dishwasher door won't latch
    Check to see if the door is not aligned correctly anymore, or if the door sags underneath the latch plate and go from there. You may need to adjust the door or replace the latch itself.
    Posted on Jul 24, 2012
    I am trying to locate an owners manual for a Frigidaire Dishwasher model # FGHD2433KW1
    Below is the link, you can download it
    http://www.manualslib.com/products/Frigidaire-Fghd2433kw1-2885301.html
    Dec 05, 2015 | Frigidaire Dishwashers
    How do I reset my Frigidaire dishwasher? eR light is flashing
    Good Afternoon Sammy, thank you for your inquiry!
    Based off the information you have provided you would like to reset your Frigidaire dishwasher because it is flashing "ER". The best way to reset your dishwasher is to flip the household circuit breaker off for roughly ten minutes. If you continue to receive the "ER" code it could be a possible problem with your main control board or keypad. I hope this is helpful information. -Matt
    Mar 21, 2015 | Frigidaire Dishwashers
    Why are the lights on the far right of the panel of the Frigidaire gallery dishwasher model #GLD8958A52 ?
    Hi friend, thank you for your inquiry!
    I understand that the panel on your Frigidaire dishwasher has lights on the far right side of the panel. I would recommend a reset on your dishwasher and you can do that by flipping the household circuit breaker in the off position for ten minutes. The lights on the right side of the panel could be providing a warning to inform the panel that something is wrong. A reset could provide an error code for further diagnosis. I hope this information has been helpful. -Matt
    Oct 16, 2014 | Frigidaire Gallery 24" Built-In Dishwasher...
    Reset frigidaire dishwasher model FDB1100RHC
    I had the same issue. I unplugged the dishwasher and plugged it back in. Bam! It's working fine now.
    Oct 16, 2012 | Frigidaire Dishwashers
    Blinking lights on frigidaire dishwasher
    Hello - Try resetting the dishwasher by disconnecting the power to the unit. This will clear most flashing lights. You can disconnect power by flipping the circuit house breaker off and back on for approximately two minutes. If this does not prove to be successful, contact a professional to move forward accurately. Dishwasher could possibly have a faulty control board or wiring failure.
    Oct 10, 2012 | Frigidaire 24 in. PLD2850 Built-in...
    Defrosted my Frigidaire freezer plugged it back in but it won't turn on
    Give it a while it might be in defrost mode. If it does not cone on after an hour I would check the defrost timer. Most of these are on the base of the freezer in front behind the kick panel. You can manually advance the timer like I did in this video:
    Sep 23, 2012 | Frigidaire Freezers
    Is there a reset for fdb1100rhs dishwasher
    I can tell you the reset sequence for the whirlpool dishwasher. I believe frigidaire are made by the same company (Electrolux).
    Press Heated Dry, Normal, Heated Dry Normal in sequence on the front panel within 5-6 secs. All lights on panel should light up. Press the cancel button to exit.
    Hope this helps.
    Aug 17, 2012 | Frigidaire Dishwashers
    Dishwasher won't start
    1) TEST some fuse blown +c. breaker trip , reset.
    2) Test the outlet wall, and reset the c.breaker house.
    3) Test the switch door, if there are defective or open the starting relais will not start the main motor see the schematic.
    May 10, 2012 | Frigidaire 24 in. FDB1050RE Built-in...
    Washing light is flashing and dishwasher won't start
    Hi
    First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
    Daniel
    Jun 19, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
    I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
    Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
    Frigidaire FGBD2438PF Gallery 24" Built-In Dishwasher Logo
    20 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Garth Jackson
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
