Question about Onkyo Ht-s3500 Receiver
The receiver turns off after yo power on - Onkyo Ht-s3500 Receiver
How do I program an xfinity remote to control an onkyo TXNR708 receiver?
There should be a code to set the remote to in the paperwork yo got with the remote and if it is not there go to the remote's manufacture's web site and see if they show the information. If not send them an e mail asking for it.
https://customer.xfinity.com/help-and-support/xfinityremotecontrols/
Aug 02, 2015 | Comcast Custom DVR 3 Device Universal...
WHEN I TURN RADIO ON SIGNAL KEEPS BREAKING UP ON ALL STATIONS. HAS BEEN OK UP YO NOW
check connections , move your antenna around should have an extra hook up for antenna for better reception most do.
Mar 15, 2015 | Audio Players & Recorders
I have ghostly carousel that will not turn changed fuse still not working any ideas can't get to the motor this is a dept 56 piece
Before yo get to the motor change yo capacitor first, and check yo magnetron for contunity of 0.2ohms and if not yo can chrck yo motor tyr n strip it
Sep 16, 2014 | Microwave Ovens
How to fix the13 pin wier card in-- Soundstream VIR-7840NR
Hola...Por que dices que el conector no te coincide??
Si es el que entra en el radio hay dos tipos, uno con 24 pines y otro de 28 pines, yo tube un problema igual y compre el conector adecuado en la pagina de power acoustik.
Jan 23, 2013 | Power Acoustik NAVIBOX-1 GPS Receiver
I have set up my dazzle platinum video creator and i get the message "No input signal"
whatever you have your dazzle connected to must be turned on and receiving video... so if yo have it connected to a DVD player, the player has to be turned on and the error message will go away.
Feb 17, 2011 | Computers & Internet
Once i put on the copier then started worming up after sometimes then error code come out "SC304" turn off the power and put it on again if the message come again call service
look my friend that messege mean pcr primary charge roller defective some times it's works but don't give charge to drum unit when yo opend drum unit look it behind drum unit yo will see solid shaft if yo look back open back cover and take off alot of thing to reach to solid shaft from behind yo will see that spring have on it big pressure and if yo pull to get normal position it will works already just close machine and opend
Feb 16, 2011 | Ricoh Office Equipment & Supplies
I am trying to adjust the bass and treble in the bass focus and t-adjust but it keeps reseting.I don't have the manual and I would like to know how to lock the settings in so I don't have to keep on...
If they reset when you turn off the radio (or the car) it is possible that you have connected the power wiring wrong. There are two 12v (+) wires. One that connects all the time to the power block (fuse block) and that one supplies continuous power to the radio unit and another that connects to the ON-OFF (ussually controlled by the Start Up Key) power side of the fuse block. If these are not connected correctly the radio re-sets everytime the key is turned of. One way to verify this is to check if yo loose your selected raio stations too.
Hope it helps.
Nov 04, 2010 | Alpine CDA-9813 CD Player
The receiver volume was cranked up. receiver
sounds like you shorted out the amplifier or one of the capacitors was overloaded.
New units have a feature that prevent the volume from being cranked up when they power up.
You will have to take it in for repair but before you do that you will need to determine what its worth.
I say this because a basic repair is going to be $150 so yo must weight whether its best to spend that money on repiring or just replacing the unit.
fair market value on your receiver is under $100 so I wouldn't recommend sending it in for repair.
here is a LINK to recently sold units
Hope that helps
Feb 15, 2010 | Onkyo TX-SV727 Receiver
No power yo frount speakers
check powersupply or check the amp driver stage voltages
Sep 17, 2009 | Yamaha RX-V2092
Onkyo Ht-s3500 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
