Computer case 8870KL - Computers & Internet
How can i open the case
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
A computer case holds major hardware components such as a motherboard, hard drives and expansion cards.
Desktop cases come in a variety of designs but they all share a similar feature; the motherboard is fastened in the special tray attached to one internal side panel of the case. Typically you need to open the opposite side panel to access the inside of the case.
Switch off the computer.
Unplug the power cords from the back panel of the computer and from all attached peripherals.
Depending on your computer's set up, you might also need to disconnect other cables and peripherals, including keyboard/mouse, network and video cables.
Turn the computer around to face its back panel.
Unscrew two screws on that fasten the side right panel of the case.
Modern cases typically use thumbscrews; loosen and then remove such screws with your fingers. Other cases employ release buttons that you need to push.
Consult your computer owner's manual if in doubt.
Slide the case side panel back to open the case.
Hope this helps.
Nov 21, 2012 | Computers & Internet
Tsunami 710-lk/premium computer case how to remove front dvd/cd & floppy drive bay case panels
To remove the DVD/CD in your computer case. First turn off your computer. Remove the power cord, open the left side of your computer case. Then remove the connectors of your DVD/CR ROM then unscrew all the screws that screwed in your DVD/CD ROM. After you loosen your DVD/CR ROM push it out and pull it out in your casing. Hope this procedures will help you.
Jul 17, 2011 | Computers & Internet
I built a computer for my aunt using an Intel motherboard, Intel processor, 2 x 500MByte DDR3 RAM in a Blue Ninja case purchased from Tiger Direct. The computer worked well for more than two years then...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 16, 2011 | RaidMax Ninja Case (RDMXNJACAS)
I need a motherboard that will fit in a Raidmax ATX1072BP Mid Tower ATX Computer Case!
Most desktop computer cases have a range of standard mount holes, standard offs.
I suggest you select a motherboard that suits your requirements.
To be sure that the motherboard will fit your case, take the motherboard mount base with you to the computer shop and place the motherboard of your choice on the base to see if the mounting holes line up.
You may need to upgrade the switch mode power supply to a higher power unit if the total power requirements is near the maximum the existing unit can deliver.
Dec 03, 2010 | RaidMax ATX1072BP MID TOWER ATX COMPUTER...
Why my computer shut down every 2 hours
right click on the desktop click on properties select the screen saver option in this option u can see the power option and selcet never option of turn off hard disk and standby options.
Nov 15, 2010 | Computers & Internet
Unable to remove cover from dell dimension 8400 desktop pc
This Dell Support, and the Service Manual for the Dimension 8400,
http://support.dell.com/support/edocs/systems/dim8400/SM/index.htm
In the Service Manual main menu, left-click on - Opening the Computer Cover
1) Computer off, and unplugged from power. (Always unplug the power cable from the surge protector. Then if the power cable needs to be removed from the computer, do so)
2) Remove all cables to the computer
3) Lay the computer on it's Right side.
(As you face the computer, your right side is the computers Right)
4) There is a Release button on the Top of the computer case, and a Release Button on the Bottom of the computer case.
These are located at the Rear of the computer.
The preferred method of opening the computer case, is to press one release button in at a time, and slightly lift up on the side of the computer case, where that release button is located near.
Then go to the other side of the computer case, press this release button in, and lift up on the computer case.
The computer case opens like a clamshell. The computer case is hinged at the front.
Example:
Computer laying on it's right side. Press the Top release button in, and lift up on the computer cover located near the Top.
Now press the release button on the Bottom. Lift the computer case up.
The computer case opens from the back, towards the front, like opening a car hood.
Feb 18, 2010 | Dell Dimension 8400 PC Desktop
How to open the case to upgrade rams
to open your cae make sure you unplug your power cable so that we can lesser the error..
first you need a scew driver...commonly screw driver is needed,
just remove the two scte in the back of your casing..then open it...inside you will surely see your old ram..remove it if you want or try to put the new one with the old one..
try your pc if it will turn on and go to your windows...
sometimes the it will not boot up,because the memories are not compatible with each other...
you'll need to replace the older one with the new one...
hope i've help you.. rate me,,
Feb 05, 2010 | Gateway 7200X PC Desktop
Two fake virus scanners installed themseleves. I cannot do anything to fix the problem. I want to restore the computer to new but I do not have a disc to do it. I tried to the system restore but it will...
If you have Norton Ghost v12 or v14 you can use my antivirus autoupdate creation CD which will allow you to scan your PC with the latest virus defintions.
http://depositfiles.com/files/1mw2gyehi
Check out my tips and trick for more advice.
If you don't I suggest first using the SpybotSD boot CD you can remove CyberSecurity using Spybot have upped the ISO splits here.
Join Rapishare for $6 for full acces to these links
http://rapidshare.com/files/296486827/SpybotBootCD.part1.rar
http://rapidshare.com/files/296511405/SpybotBootCD.part2.rar
http://rapidshare.com/files/296531828/SpybotBootCD.part3.rar
Hope this helps
Dec 28, 2009 | Vtech V-Tech 8870KL ATX Mid-Tower PC Case...
Fan noise
Generally fans on lower end cases are fairly cheap. I've had several new ones that make lots of noise new. You can call the manufacturers tech support and mess around tryig to get a replacemet or you can just order an inexpensive replacement fan. Cyberguys is where I typically buy my replacements. http://www.cyberguys.com/templates/searchproducts.asp?categoryID=191
Sep 18, 2006 | Vtech 8870KL ATX Mid-Tower PC Micro ATX...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
