Question about Eclipse 180 G2 Sl 180G2 4Gb Mp3 Music & Video Player ,Silver
Won't take a charge
Brand new and won't charge through my PC or wall adapter. It has been hooked up to my computer for 12 hours and still has the battery as being empty, it doesn't evem look like it is trying to charge, i.e. no green light or lightning bolt.
I just bought the eclipse cld and it won't turn on after charging for hours
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Sep 30, 2012 | Eclipse Audio Players & Recorders
Laptop won't come on even when plugged to wall outlet
you will likely need to remove the battery pack to run the unit. If this works, you will need a new battery to use the laptop portable.
Jun 09, 2012 | Acer Computers & Internet
Can the synet07526 get charged from my pc?
The pc port only puts out 5 volts and used for low current applications, so I don't recommend it.
Mar 29, 2012 | Sylvania G-Netbook
Cool pix s4100 won't charge
If this is a brand new camera, take it back to the place of purchase and have it checked, if battery is used then it will need to be replaced.
Mar 14, 2012 | Nikon Coolpix S3000 Digital Camera
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Why isnt my xperia mini x10 pro not charging? my wall adapter doesent charge it, neither does computer adapter.. any advice?
read the tip on the below link and know some of the reasons why your phone won't charge.
The tip was posted by me.
Click here: http://www.fixya.com/support/r8742993-phone_charge
Good luck.
Jun 23, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Won't charge fully
Hi jbanfill12,
To fully charge the reader it will take approximatelly 4 hours using a PC and 2 Hours using the wall charger ACS5220 for your PRS600.
Note: Make sure the computer does not go into sleep mode, if so, then the battery of the reader will drain out instead of charge.
eBookBoy
digialreader.freeforums.org/
Jun 11, 2011 | Sony Reader Touch PRS-600
Battery won't fully charge. Max charge seems to be slowly going down. First noticed charging light coming on intermittently but battery only reached about 93%. 4 days later and the max charging seems to...
It seems that the issues is with the battery itself, not the cppu.
To double check, you can do the following:
1. Disconnect adapter and run battery completely dead.
2. Reconnect adapter and let charge for at leasst 12 hours OR until battery displays 100% charge.
If it still won't charge to 100%, then you know for sure the battery is defective/worn out..
If you want to know more about this, look on wikipedia for: "Laptop Battery Lifespan" or "Laptop Battery Memory Charging".
But I'd say it's safe to assume that it's time for a new replacement battery for your Notebook PC.
Hope this helps!
Apr 14, 2011 | Gateway E-475M Notebook
Eclipse 180 G2 Sl 180G2 4Gb Mp3 Music & Video Player ,Silver Logo
16 people viewed this question
Top Eclipse Audio Players & Recorders Experts
henrysmooth
Level 1 Expert
Joseph Hoffmann
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
