Question about Epson XP-200 Multifunction printer
Printer in error state
Doesn't print with error state message
Printer wont print
then its time to throw your printer in the "ERROR"
Apr 13, 2014 | Canon Pixma MX410 All-In-One Printer
I replaced a lexmark x4650 black ink cartridge #36 with another lexmark #36. when I try to print I get an error message stating that the left cartridge(the one I replaced is incorrect). Any suggestions?
You might have put it in incorrectly. Sometimes it could be as simple as taking the cartridge out and putting it back head but make sure it is snapped in correctly. Also, you could try unplugging the machine, taking the cartridge out and then replacing it once the machine is on. That could work as well. If it doesn't let me know.
Jul 26, 2011 | Lexmark X4650 InkJet Printer
My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
Jun 18, 2011 | Lexmark X2670 All-In-One Printer
When I print a photo, vertical lines appear throughout the photo. The ink cartridges are new. No error message appears on screen.
Please state the model of your printer.
Vertical lines appears on prints because the nozzles on your print head are blocked, it doesn't means all nozzles but some of your nozzles are blocked. A print head of an inkjet consists of many tiny little pores or nozzles, through which jets of inks are sprayed on the photo paper to create an image, if some of this tiny pores are blocked print outs deteriorates, so cleaning the print head is an option if your printer has print head inside the printer you can first clean it through the head cleaning option present in the maintainence tab of your printer software, for printers that have print head on the cartridges, you can add a few drops of isopropryl alcohol on the print head and leave it for a minute and put it back on the printer and run the head cleaning utility of your printer software.
Hope this helps you.
Apr 28, 2011 | Office Equipment & Supplies
Epson XP-200 Multifunction printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
