Can I attach an external on/off toggle switch to iheater 1500
Original on/off switch popped off
4 Suggested Answers
  • 33 Answers
SOURCE: when I attach an external monitor the f5 key does
goto your control planel select display settings on the notebook to adjust the selected monitor. Than test monitor 1 or 2. What OS are you using it is alittle diffence. XP or vista; vista has personalization and xp go into display properties.
Posted on Jul 19, 2009
tucdoak
SOURCE: Iheater 1500 I bought a replacement switch but
Where did you get the switch from ?
Posted on Dec 01, 2014
gopakumarg43
  • 75462 Answers
SOURCE: iheater 1500
Ok. Looks too good
Posted on Dec 28, 2015
I need a wiring diagram for an Iheater 1500
Request the wiring diagram directly from Iheater.
Mar 31, 2018 | Heating & Cooling
We have an iHeater 1500 and lost the remote. Where can we get a replacement? I was under the impression that replacement remotes were free for life.
U from this planet? Free for life?????? Try to get an original replacement since universals only have the most basic of functions and often do not serve purpose - cannot get into menus, etc.
Sep 11, 2017 | Televison & Video
What causes it to shut off?
I found nothing... iHeater 1500 Advanced...
(MY fault: strongly suggest the TELEPHONE)
Try
officialiheater.com
http://officialiheater.com/
or follow contact instructions (below)
Please be sure to read and follow all of the service
procedures outlined in this owner's manual. If you have
any questions concerning your iHeater, contact the
iHeater Customer Service Department at 1-800-469-0456
1-800-469-0456
iHeater, LLC.
5789 Park Plaza Court, Indianapolis, IN 46220
www.officialiheater.com
Carnac the Magnificent
Jan 02, 2016 | IHeater 1500 Advanced Infrared Heater...
My iheater (iH1500) seems to be missing a fusable link located in the back center of the unit. Can I get one to replace it. The unit doesn't power up.
If you believe it is not powering up because of a blown or missing fusible link, you can simply BYPASS the fusible link with a (large) piece of wire, briefly turning the power on to test the unit. If the unit powers up with the bypass wire (and it does not blow the fuse or breaker to that outlet)... leave the bypass wire there!
May 14, 2015 | IHeater 1500 Advanced Infrared Heater...
I have a I heater that will not turn on. Last time it worked fine. What should I check ?
first check the outlet its plugged into to be sure there is actually power there, if not check your breaker box, it may have overloaded the circuit and popped the breaker. if all good there, check the unit for a fuse, which may be blown.
Oct 11, 2014 | IHeater 1500 Advanced Infrared Heater...
My iHeater shuts off
Our heater cuts off after 2 mins or less and it shoe 90 on the temps diplay. Had it for a couple of years. It's been vacuum and clean and still the same results. I don't have the schematic or the owners manual..
Jan 17, 2014 | IHeater 1500 Advanced Infrared Heater...
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Nov 12, 2013 | IHeater 1500 Advanced Infrared Heater...
How do I fix the toggle switch on my popcorn machine?
Trust me, rather than trying to reassemble the original switch, it'd be easier to just replace the switch.
Replacements are out there....example:
http://www.radioshack.com/product/index.jsp?productId=2062525
Now you'd just have to figure out if the original is a SPST or a DPDT, or some other configuration.
Sep 23, 2013 | Kitchen Appliances - Others
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
