Question about Lands Phones
How do i reset originaL bandwidth uniden ezi33xlt
How do I reset uniden uh7700nb to original factory settings
type into search engine what you need un7700nb service manual
Oct 10, 2014 | Uniden Radio Communications
How to reset to factory original settings?
you need to get a service repair manual for the type radio you are talking about. you can go to www.cbtricks.com and get just about any manual you need. wouldn't buying another one be cheaper and better?
May 07, 2014 | Uniden Radio Communications
Resetting the scanner clearing all memories
Power the scanner OFF. Press and hold the 2, 9, and HOLD keys and power the scanner ON. This procedure will clear all programmed frequencies and return the scanner to its original factory settings.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC340CRSom.pdf
Bill B.
Listening in since the 60's
May 30, 2011 | Uniden BC340CRS Base Scanner
What do I enter for 464.2125? My Uniden BC95XLT only accepts six digits. So, the 5 is left off? Does this affect the operation?
Just forget about the last digit. Receive bandwidth is wide enough that your reception will be fine -- unless there's an active station on 464.2120.
Bill B.
May 29, 2011 | Uniden BC-95 XLT Scanner
How to clear a uniden bearcat bc760xlt
To RESET your scanner:
- Power it OFF
- Press and hold the 2, 9, and MANUAL keys and power the scanner ON
This procedure will erase all programmed frequencies and return the scanner to its original factory settings.
Bill B.
Dec 10, 2010 | Uniden BC-95 XLT Scanner
How to reset my uniden 780xlt scanner
There is no "soft" reset for the BC780XLT, and the following "hard" reset will erase all programmed data and return the scanner to its original factory settings.
- Power the scanner OFF.
- Press and hold the 2, 9, and MANUAL keys and power the scanner ON.
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC780XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Jun 30, 2010 | Radio Communications
How do iclear to reset
Resetting the scanner automatically clears all frequencies from memory and restores the unit to original factory settings. To RESET your scanner:
- Press and hold the 2, 9, and HOLD keys and power the scanner ON.
- The word CLEAr will appear after about 3 seconds, indicating that the scanner is ready to accept new programming.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 10, 2010 | Uniden Nascar BC-92T Scanner
Phone will not ring
reset your phone to original factory settings ( procedure will be provided in the instruction manual) ..... hope your problem is tackled. thanks for using fixya!. please dont forget to rate my solution.
May 27, 2009 | Uniden 5.8GHz Dual Cordless Phone
Uniden dx18560-2
If you are by a microwave it is in the same bandwidth and can cause that problem even if you change channels. See if that is the problem
Nov 05, 2008 | Uniden Cordless Phone
Lands Phones Logo
37 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
