Question about Horizon AFG 7.1AT Treadmill
Change language on afg 7.1AT - Horizon AFG 7.1AT Treadmill
I have a AFG 4 in 1 covertible crib and need the assembly instructions
Hi Abigail.
This was a challenge to research. I did come up with this, for the AFG 3 in 1
AFG Nadia Crib Assembly Instructions which I hope may be enough overlap to allow you to get your crib together.
I hope this helps, and Happy Holidays!
D
Dec 14, 2015 | AFG Baby Gear
Athena Naomi 4-in-1 Convertible crib. I lost the instructions
Your crib was made by a company called AFG through WayFair. You can reach WayFair at this number and request instructions. You can also see the cribs here: http://www.wayfair.com/AFG-Furniture-C455042.html
877-WAYFAIR (877-929-3247) Mon - Fri: 8am to 12am EST, Sat: 8am to 8 pm EST, Sun: 9am to 6pm EST
Sep 12, 2014 | AFG 009E Athena Naomi 4-in-1 Convertible...
Horizon AFG 13.0 AT Treadmill slows down after 15 min and a grinding noise from the flywheel
first unplug the trendmill and expose the motor. on the motor is a disc shape cover, remove it and you see ampreture, take a eraser on a pencil and clean the ampreture. Do this by rubbing the eraser on the ampreture and rotate it while your cleaning it
Jan 12, 2013 | Horizon AFG 13.0 AT Treadmill
Changing kilometer from mile on afg 7.1at treadmill
Hi there. I add the same problem as well. Below are the steps I used to fix my problem.
In order to switch your distance calculation between miles and kilometers, please follow these instructions:
  1. Turn on treadmill, put safety key in place
  2. Press and hold the INCLINE + and SPEED - keys for about five seconds or until machine beeps three times. En90 or Eng0 should appear.
  3. Use the SPEED + key to navigate to En93.
  4. Press ENTER once.
  5. Press START to choose unit (miles or km). The display will change accordingly.
    1. Miles: 0
    2. Km: 1
  6. Press and hold STOP or exit and replace the safety key to return to the normal start screen.
NOTE: To be sure that the treadmill is displaying your desired unit, simply press START and observe the first start speed to display. If it displays 1 or .5, it is in miles. If it displays .8 or 1.6, it is in kilometers. Also note that by changing in metrics the Lbs will also convert to Kg.
Hope this help.
Dan
Dec 25, 2012 | AFG 7.1AT Treadmill
I lost my instruction for my AFG nadia 3 in 1 crib i want to turn it in a bed
Since I've noticed there are an abundance of parents looking for this and yet its not available online anywhere, I have uploaded it and you can find a pdf version of the manual for the afg nadia crib here: AFG Nadia Crib Instructions
Enjoy!!!
Oct 24, 2011 | AFG Nadia Crib
I need the assembly instructions for the AFG Nadia 3-in-1 convertible crib
lost instructions and dont know how to change into a toddler bed
Jan 14, 2011 | AFG Nadia Crib
I bought a Garmin Nuvi 1350 GPS. How do I change the language into English?
. Setting the Languages Voice Language--change the language for voice prompts. Touch tools > Settings > Language.
text Language--change all onscreen text to the selected language. Changing the text language does not change the language of user-entered data or map data, such as street names. Keyboard--select the keyboard for your language.
Touch Mode on any keyboard to change the keyboard language.
Sep 02, 2010 | Garmin GPS
No digital readout
Hello derek143
You Said,
I have a Whirlpool upright freezer AFG 371/H there is a digital display and lights and buttons, on/off temp alarm etc running across the top of the freezer. None of this works but the freezer is still freezing. i have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
Sep 11, 2008 | Freezers
AFG Daphne Crib
i need to assemble my crib, but cant find instructions.where can i find them on line
Oct 12, 2007 | AFG Daphne Crib
Horizon AFG 7.1AT Treadmill Logo
22 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Jerry Kramer
Jerry Kramer
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
