Question about Dell Computers & Internet
Laptop will not respond to password following power cut
Following power outage laptop will not open. Says the password is incorrect when it is correct.
    Master:
  • 779 Answers
Shift / Caps locked?
Posted on May 05, 2014
myob247
  • 1342 Answers
SOURCE: Compaq Presario 1255
Check this site for some tips and tricks that may help you.
Posted on Jun 27, 2008
  • 47 Answers
SOURCE: Bypass HDD password
From what I understand, the hard drive can be set with a password so the drive can't be used in any other computer or even opened if stolen. It is different from windows or bios passwords, and no password unlocker can open it.
You need to call the manufactor of the pc, and have all the information about the computer handy so it can be proven you are the legal owner. They are the only ones that I know of that might be able to reset or disable the HD password.
Posted on Jul 12, 2008
  • 3940 Answers
SOURCE: ERROR MESSAGE
There has been a hard drive password initiated on the system by someone. If you do not have access to the password, you'll need to contact Dell Technical Support (800-624-9896) and after you verify ownership, they can generate a password to access the hard drive.
Posted on Aug 19, 2008
tat4u
  • 520 Answers
SOURCE: I need a master password a amilo m700 reg no ms2137 snr3793030039
I have software to remove all passwords windows or bios ;runs in windows and as a bootdisk.(to reset bios/remove passwords)
if you want a copy send ur email and I'll give you my link to download the iso(disk image)to write to a cd.
Posted on Jan 30, 2009
  • 76 Answers
SOURCE: My acer laptop is locked because the password is
Please try loggin in another Account With Admin Rights and remove the Password. IF there are no other account then you can try using the Coommand Prompt to reset the User Password.
Follow the Commands in the Order.
1)Restart the Computer and keep on tapping the F8 key, This will Launch the advanced Boot options.
2) Now select the Safe Mode with Command Prompt option.
3) Type Net user and hit enter.
4) Now type the net user User account name(for which you want to reset the Password) * and hit enter
Syntax: net user xyz *
5) It will prompt to enter the Password, Hit enter Twice without typing anything.
6) The Password is resetted successfully.
7) Restart the Computer and enjoy
Posted on Nov 23, 2010
You need to remove the password. Local laptop tech can do it and usually it cost $25 - $50.
Feb 15, 2014 | Sony VAIO VGN-FS840/W Notebook
I turn on my aspire one and i get a screen stating the following primary master hitachi hts543216l9slock when i press enter it asks me for a password i dont have. what can i do?
This is known as a Boot Password. Cut power to the laptop, and remove the battery. If you can remove any panels from the bottom of the laptop, and locate the tiny CMOS battery, remove it for 3-5 minutes. It may even be under the keyboard. Once this is left out for 3-5 minutes, the CMOS should reset.
Aug 23, 2011 | Acer Aspire One PC Notebook
Reset password cmos toshiba satellite A65-s1064
The only way to reset the cmos battery is to remove the battery from the back, open the bottom of the laptop and remove the button battery for 3-5 minutes. Replug in the battery and close up the case. Once completed, you can then create a new password.
Apr 08, 2011 | Toshiba Satellite A65-S1065 Notebook
Please help me i forget bios password in my laptop dell model is 1525 how can i open it
To reset the BIOS password in your Dell Inspiron 1525 you would first need to disassemble the laptop and remove the CMOS battery for 30 seconds and put it back in. You can do this by following the service manual below provided by Dell.
Please be aware that this will take some technical knowledge to do, making a mistake here can be fatal to the operation of your system. I urge you, if you are not comfortable following any of these steps, take it to a local professional.
Service Guide
Oct 20, 2009 | Dell Inspiron 1525 Laptop
Phone has error code 507 with a square and a triangle, and a line running trough it
Cause:
This error message can have the following causes:
While using the Application Loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
All data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
The Power Management feature on the computer turns off the USB ports.
The BlackBerry smartphone is connected to a laptop computer using a docking station.
Resolution
The following are possible resolutions for this issue.
Cause 1
Resolution 1
Complete the following steps:
Verify that you have the BlackBerry Device Software installed on your computer. For instructions, see KB03295.
If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
Open BlackBerry Desktop Manager and double-click the Application Loader icon.
Use the Application Loader tool to install the BlackBerry Device Software.
Cause 2
Resolution 2
Open BlackBerry® Desktop Manager and double-click the Application Loader icon.
Cause 3
Note: This resolution is for Windows® XP users only.
Resolution 3
On your computer, click Start > Settings > Control Panel.
In the Control Panel, double-click the System icon. The System Properties window opens.
Click the Hardware tab of the System Properties, and click Device Manager.
In the Device Manager, double-click Universal Serial Bus Controllers.
Right-click the first USB root hub, and click Properties.
In the Properties window, click the Power Management tab.
Clear the Allow the computer to turn off this device to save power check box.
Repeat steps 5 to 7 for all other USB root hubs.
Restart your computer.
Cause 4
Resolution 4
Disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer using a USB cable.
Re-install the BlackBerry Device Software using the Application Loader tool.
May 17, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Forgot password
On the Thinkpad's, it's a fairly easy process to reset the passwords. Try the following steps and you should be able to access the computer...
1. Power off the lpatop.
2. Flip the laptop over and open the Memory cover. It should have the diagram of a Dimm on it.
3. Short-circuit the two password pads or put a jumper on the contacts to short the circuit.
4. Remove the jumper, or whatever you used to short the password pads and put the cover back on the bottom of the laptop.
5. Power on the laptop and you should be fine.
Kerry L
Apr 07, 2009 | IBM ThinkPad T21 2648 Notebook
The router was working perfectly until there was a power outage.
You may have to enable the wireless function on your router. To do that, you need to access the router as an administrator. Make sure your computer has an ethernet cable to connect between it and your router. Open your web browser and type the following into the address bar: http://192.168.0.1 or it is 192.168.1.0 (I can't recall at the moment). The username should be administrator or admin and the password is either blank or the word password. After logging in, you should see some tabs and one should say wireless. It is on this screen where you want to verify that wireless is enabled on the router.
Mar 24, 2009 | Linksys Wireless-G Broadband Router
Reload software 507
Cause:
Resolution
Cause 1
Resolution 1
Cause 2
Resolution 2
Cause 3
Resolution 3
Cause 4
Resolution 4
Feb 18, 2009 | RIM BlackBerry Bold 9000 Smartphone
Power on password on nx6310 hp compaq
Welcome to FixYa! You have a laptop that is one of few that HP provides a command line procedure for. Follow these steps and you will be able to reset that password. If you have forgotten the first password then disable it as for any other brand/model it is an unforgiving procedure to undo that action.
 Resetting the Computer ( These steps also clear CMOS): 1. Enter an incorrect password and press enter. 2. Repeat Step 1 two times. After the third entry of the incorrect password, the computer responds with a “System Disabled” message and provides an override password. 3. Access MS/DOS by clicking Start > All Programs > Accessories > Command Prompt. 4. Enter “unlock6 xxxxx 0,” where “xxxxx” is the password generated by the computer in Step 2. The computer responds with another system-generated password. This password can be used to reset the computer and clear all CMOS settings.
Please post back if you need further assistance or simply rate a FixYa for me if you are successfu. Steve Medley
Jan 28, 2009 | HP Compaq nx6310 Notebook
Power on password solution
If it really is a power on password you can remove it by following these steps.
1) Unplug your laptop.
2) Remove all batteries.
3) Then you must open your laptop and locate the cmos battery and unplug it for about 3-5 seconds.
4) Then put it back together and power it on.
Dec 04, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
