Question about Whirlpool Whirpool 3.5cu ft Top Load Washer w/
Washer goes throuh the wash cycle, but then won't spin the water out
    Sergeant:
  • 239 Answers
Bad pump...
Posted on Feb 16, 2014
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
How many washing cycles does the Cabrio top load washer have?
Read your Manual, that just might be a first starting point.
Otherwise 2WD, 4WD and it may be the transfer case?
Sep 07, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Whirlpool trouble shooting
All Spin cycles regardless of load or even when unloaded and spinning?
If so suspension is broken.........Technician repair only, even the balance weights in the tub are too heavy for DIY to remove and replace springs
Sep 07, 2014 | Whirlpool WFW9550WW Duet 27" 4.4 cu. ft....
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
Whirlpool4930xw0
Transmission timer belt solonoid ???? Take your pick. Motor is probably good because it drains
Good luck,
Marty
Nov 24, 2013 | Whirlpool WTW4930XW 27" Top-Load Washer...
Wtw5500xw2 will add some water, senses for a very long time. Sometimes it makes it to the "wash" cycle but nothing happens. When you come back later the machine is off and the lid is unlocked as if it...
Un plug it for a few minutes or even overnight and plug back in, that will reboot the electronic control, if that doesn't fix it and you do not have a good honest local repair shop call Sears. Good Luck
Oct 12, 2013 | Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top...
Washer does not drain
1.), Pump may be bad. Check voltage to water pump in Spin Cycle. If you have voltage at the pump, but it does not run, replace the pump.
2.) If you have voltage to the water pump, and can hear or feel it running, cut power off, and remove the boot which is directly below the wash bin. The boot empties into the water pump. You will need long needle nose pliers or better, use water pump pliers to remove the straps holding the rubber piping to the pump and the boot. Remove debris from the boot, i.e., bobby pins, coins, socks, pens, keys, etc.
3.) If no voltage comes to the pump in spin cycle, you may need a new timer.
4.) Install a new belt on the motor pulley. You will regret not replacing the belt later.
Feb 02, 2013 | Whirlpool Whirpool 3.5cu ft Top Load...
Whirlpool Whirpool 3.5cu ft Top Load Washer w/ Logo
29 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
