Question about AFG 7.1AT Treadmill
Problem with AFG 7.1AT Treadmill Changing language
Afg 3.5 treadmill incline is stuck at zero and won't work. Motor gets very hot.
If you wish to get some details about treadmill repair and maintenance then check the following link
http://electro-medical.blogspot.com/
Oct 04, 2016 | Exercise & Fitness
When I switch the machine on it says 501 in the heart beat box then goes blank then reappears with --------across all the screen ....
reset the treadmill and try again.
adjust the reed switch see the diagram attached. Clean it+test for open +tight the connector very well.
Jul 30, 2013 | Horizon AFG 5.0 AT Treadmill
Horizon AFG 13.0 AT Treadmill slows down after 15 min and a grinding noise from the flywheel
first unplug the trendmill and expose the motor. on the motor is a disc shape cover, remove it and you see ampreture, take a eraser on a pencil and clean the ampreture. Do this by rubbing the eraser on the ampreture and rotate it while your cleaning it
Jan 12, 2013 | Horizon AFG 13.0 AT Treadmill
Changing kilometer from mile on afg 7.1at treadmill
Hi there. I add the same problem as well. Below are the steps I used to fix my problem.
In order to switch your distance calculation between miles and kilometers, please follow these instructions:
  1. Turn on treadmill, put safety key in place
  2. Press and hold the INCLINE + and SPEED - keys for about five seconds or until machine beeps three times. En90 or Eng0 should appear.
  3. Use the SPEED + key to navigate to En93.
  4. Press ENTER once.
  5. Press START to choose unit (miles or km). The display will change accordingly.
    1. Miles: 0
    2. Km: 1
  6. Press and hold STOP or exit and replace the safety key to return to the normal start screen.
NOTE: To be sure that the treadmill is displaying your desired unit, simply press START and observe the first start speed to display. If it displays 1 or .5, it is in miles. If it displays .8 or 1.6, it is in kilometers. Also note that by changing in metrics the Lbs will also convert to Kg.
Hope this help.
Dan
Dec 25, 2012 | AFG 7.1AT Treadmill
How to fold my afg 5.0 treadmill for storagae
Dear Sir: Hello , i hope everythign is o.k
Please do the following:
FOLDING Firmly grasp the back end of the treadmill. Carefully lift the end of the treadmill deck to the upright position until the foot lock latch engages and securely locks the deck into position. Make sure the deck is securely latched before letting go. To unfold, firmly grasp the back end of the treadmill. Gently press down on the foot lock latch with your foot until the lock latch disengages. Carefully lower the deck to the ground. NOTE: on some models the foot lock latch might be on the right hand side. NOTE: when folding the Horizon Fitness Treadmill the console assembly will tilt away from you, but will return when fully folded in the upright position. Please allow two additional feet from wall when folding.
Thank you in advance, sincerely. Blessing.
If you need additional help, please contact me.
e.cuadra Managua, Nicaragua C.A.
Sep 25, 2011 | Horizon AFG 5.0 AT Treadmill
I turn the treadmill on and it has a message saying that the safety key is off. How do i turn it on?
Your safety key is the magnet switch with the cord attached to it on the front of your computer. If the computer says the key is off then try repositioning the safety key magnet. If it still doesnt work you may have a loose wire behind the key section.
Feb 10, 2011 | Horizon AFG 5.0 AT Treadmill
There is a clicking sound coming from the motor. Everything runs great except for the sound that accelerate at the same time as the speed.
hi,
check the motor, may be its bearing have some problem. if u can see the motor then put some oil on its bearing. take care open treadmill only after removing the power.
ok
Dec 23, 2010 | Horizon AFG 5.0 AT Treadmill
Making a loud whirring noise when running.
hi i think that the running belt is too loose and touching the underbody of the treadmill, if you can have a look underneath.
Nov 15, 2010 | Horizon AFG 3.0 AT Treadmill
Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Jun 10, 2010 | Horizon AFG 5.0 AT Treadmill
AFG 7.1AT Treadmill Logo
Top AFG Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an AFG Exercise and Fitnes Expert? Answer questions, earn points and help others
