Question about Frigidaire Washing Machines
Washer not draining at end of cycle - Frigidaire Washing Machines
  • Frigidaire Master
  • 5,323 Answers
BLOCKED OR CLOGGED HOSES OR WATER PUMP
Posted on Apr 01, 2015
5 Suggested Answers
  • 87 Answers
SOURCE: Washer does not drain water
You have a sock in the pump. If no noise in spin you have a bad lid switch.
Posted on Jun 08, 2007
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 13 Answers
SOURCE: washer is not draining at end of cycle-puddle in
Some of that is normal, if you turn the drum around you will here water. Mine do it also.
Posted on Feb 13, 2010
TheMobilian
  • 8220 Answers
SOURCE: washer is on but went i select to drain and spin
You may have something inside the pump, blocking the progress of the draining Their are screws under the bottom you remove to get the bottom plate off c1a7e9d.jpg330474c.jpg
Posted on Mar 05, 2010
Whirlpool Duet washer does not indicate end of cycle and unlock door
Most times this problem can be caused by a blocked tube to the pressure switch,..
Mar 03, 2014 | Whirlpool Washing Machines
Blanco BFW716
Sounds like a defective timer
Aug 24, 2013 | Washing Machines
Washer is on but went i select to drain and spin
Mar 05, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My washer won't drain near end of cycle. Motor
The problem will be on the main board or the power supply board of the machine might have some problem kindly the check the wire lines as well
i do not think that drain pump is having any problem
Dec 30, 2009 | Kenmore 42822 Front Load Washer
Washer constantly draining after first cycle
For the machine to keep filling it would indicate that there is a siphoning problem. Check the outlet hose is not running along the ground, it has to rise up then loop back down or the water will just run straight down the drain. If the problem only happens after the first pump out it would indicate the end of the outlet hose is lower than the drum or there is no air break around the outlet hose. (The stand pipe should be larger in diameter than the hose from the machine).
http://selfix-uk.co.uk/under%20sink%20plumbing.html
May 01, 2017 | GE Spacemaker WSLP1100D Top Load Washer
End of cycle spin
my washer will not drain unless if the boot is squeezed.
Aug 17, 2008 | Frigidaire GLTR1670A Front Load Washer
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
18 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
