Question about Craftsman Snow Blower / Snowblower Bottom Cover :
How to take auger out of snowblower
Video of auger removal
    Master:
  • 755 Answers
This is easy job look at it , it will show you how it is done , just look good at it you do not need anything to do this couple of hand tools
Posted on Feb 03, 2015
Replace snowblower belt
Locate the two top auger housing fastening bolts and remove. The auger housing will tilt forward and then lift the housing off of the bottom 2 bolts/bushings. You will need to support the traction frame as it will try to fall onto the handles.
Feb 27, 2017 | Mtd Garden
Where can I find detailed instructions on replacing an auger?
first remove the chute. then remove the bolts holding the auger in place. then rotate shaft by hand and find the two roll pins that hold auger assembly shaft. drive these pins out and you auger will slide out the front of unit
Aug 28, 2014 | Yard Machines 26" 208cc Two Stage Snow...
Continuous clunking when i engage the auger on my snowblower
check for bent blower and auger blades
check rear blower bearing, engine off( grab rear of shaft pull up and down) shouldnt move very much. if it does bearing bad
Dec 28, 2013 | Craftsman 22" 179cc* Dual-Stage Snowblower
Not sure how to reroute auger cable on craftsman snowblower
I assume the cable to the auger was removed and needs to be re-installed.
There should be a clamp that the cable ran thru, then attaches to the auger
control. Find this clamp on your snowblower, and route it thru this clamp
then attach it to your auger control.
Feb 25, 2011 | Garden
How to remove the belt from craftsman snowblower model C459 52560 MFG code 1/055/3-0079
Unfortunately like many other snowblowers you first need to seperate the auger/blower assembly from the drive/engine assmbly. Pretty straight forward after that. Make sure you put belts on the right side of the metal tab that cleans the back side of the belts when running or you'll they'll cut in two the first time you engage the auger
Dec 17, 2010 | Kitchen Ranges
How do i change the auger belt on a honda hs 70 snowblower?
Remove the auger belt housing cover 4 bolts (10mm), if you are lucky, you can take the belt out, or just cut it. The slide the new belt between the auger and driving pulleys. there is a break pad under the auger pulley, so have someone engage the auger handle and put the new belt on the auger pulley. Or you can remove 10 12mm bolts and separate the auger and engine. Even though you have remove more bolts, it is easier.
Nov 26, 2010 | Garden
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
How do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Oct 12, 2009 | Ariens Garden
HALF OF AUGER NOT WORKING
When you got something caught in the auger, the shear-pin probably did it s job and broke, to save the gear box. Remove the old shear pin and install a new one
Mar 02, 2009 | Craftsman 16" High Garden Tractor Snow and...
Craftsman Snow Blower / Snowblower Bottom Cover : Logo
137 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
